Home > In Car Electronics > Grommet and connector references
flyingfab
France 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
Hello Very Happy
I am fitting additional long beam headlights onto my Defender and I would need some LR references and good tips. I think Defender2.net is the best place for asking Wink
1) In order to get my wires into the battery box, I would like to swap the rigid capping currently fitted with a rubber grommet (like the one on the right hand side of the picture). It is approximately 4-5cm wide. I am looking for the LR reference for this grommet ...
2) I have a free connector, under my cubby-box, which is probably designed to connect the optional factory Alpine subwoofer. I would like to use the positive and earth from this cable to connect the switch that will drive my headlamps' relay. Would someone know where I could find a "male" connector which I could crimp then plug into this one ?
3) Any idea of the reference of the cable-tie pictured on this drawing ? (it is from the LR headlamp installation manual)
Thanks in advance !! Very Happy
Fabien
Post #631838 16th Jun 2017 3:25pm
gilarion
Can't help with the connectors but the cable ties with fir tree look here
https://www.ebay.co.uk/sch/i.html?_odkw=ca...p;_sacat=0 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #631839 16th Jun 2017 3:30pm
flyingfab
Great Very Happy I didn't know that this was was called "fir tree" ... Thanks a lot !
Just missing the grommet and connector references now Mr. Green
Post #631896 16th Jun 2017 10:49pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
You can get various grommet styles to suit from companies like these guys Thumbs Up Thumbs Up
http://www.polevolt.co.uk/acatalog/Grommets.html 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #631911 17th Jun 2017 7:35am
zsd-puma
there is enough free play in those grommets to push extra cables throught them along side the existing cables, even if you put the extra cables in additional (smaller) conduit. Land Rover themselves advocate this when fitting the towing electrics for example.
Post #631922 17th Jun 2017 10:45am
flyingfab
Good to know Thumbs Up But I prefer to use an additional hole/grommet. This makes my work easier, since I usually crimp and make the whole wiring on a workbench, including fitting the grommet onto the wiring ... then fit it onto the car. That's why I need to a dedicated grommet Mr. Green
Thanks Jomara ! That will be useful for another work ... but quite different from what I'm currently looking for. I am really looking for the factory style grommet Wink
Post #631932 17th Jun 2017 12:47pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I don't know whether this is any good for you but on my older Defender there is are 2 grommets on the tunnel part of the bulkhead which are easy to get access to via the cab, under the carpets.
It's number 11 on this diagram and the part number is MTC1650, there is one either side. I used one of them to run a cb aerial into the cab
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #631936 17th Jun 2017 2:17pm
PaulMc
Unfortunately, Polevolt only post to the UK Sad
Land Rover don't list the battery cable grommets separately, they come with the battery cables.
However, they do list these grommets as spare parts, you'll have to measure the diameter of the hole to determine the correct size -
http://new.lrcat.com/#!/1235/2632/2988/227
The style of grommet you need is Callout 2, the part numbers for which, are -
233244 - GROMMET BLACK CABLE 3 X 19MM
233243 - GROMMET BLACK CABLE 3 X 25.5MM
269257 - GROMMET BLACK CABLE 6 X 33.5MM
555711 - GROMMET CABLE 6 X 33.5MM RED
276054 - GROMMET BLACK CABLE 6 X 41.5MM
589452 - GROMMET BLACK CABLE 7 X 53MM
233566 - GROMMET CABLE 12.5 X 48MM RED
. Paul.
Post #631942 17th Jun 2017 3:43pm
flyingfab
Yes Thumbs Up I'll take the measurement but I'm pretty sure one of those will fit perfectly !
Many thanks Wink
Post #632016 17th Jun 2017 10:58pm
flyingfab
Ouch ! Finally, according to my measurements, none of them will fit perfectly (diam. 4.7mm) Big Cry
The closest would be the the ref.233566 ... but its 12,5mm hole is too wide, I'm afraid.
So, I'm considering drilling a 25mm hole into the rigid capping in order to fit a rubber grommet on it. That might work Whistle
Post #632164 18th Jun 2017 11:00pm
flyingfab
Hello !
Some unexpected (good) news : I finally realized that the free opening was probably smaller than I initially thought.
So, I ordered a grommet ref. 276054 (6 X 41.5MM), just in case I would be lucky. And I was : this grommet fits perfectly well in the opening !!
Thanks you all for your good tips Very Happy
Fabien
Post #633587 25th Jun 2017 10:33pm
As that grommet fits perfect that's brilliant. (Thank you for letting us know Fabian.)
I assume the hole is 40mm or possibly 41 mm dia? If the grommet is 41.5 dia.
I don't suppose anyone knows off the top of their head?
If not I can accurately measure anyway, I may need an additional hole or two added for cable routing. No Guts, No Glory.
Post #725544 26th Aug 2018 8:55pm
It's probably 42mm or thereabouts. The spec. of the grommet will be for the hole it fits in rather than the outer diameter. Darren
Post #725554 26th Aug 2018 9:56pm
Ah yes, good call I'm thinking of the dimensions the opposite way around aren't I. Thumbs Up
I'll give it a measure with the micrometer to be sure.
I was considering using ip68 glands but the just don't look right especially from underneath.
(Mainly because of their size and protrusion.) No Guts, No Glory.
Post #725561 26th Aug 2018 10:40pm
Linds Hanson
Later battery cable grommet through seat box is 12.5X48 mm part number 233566 But £8.50 each minimum quantity 5!
Post #1052108 18th Nov 2024 4:46pm
