Home > Technical > Puma Speed Pulse for Sat Nav? |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
hi, looking at the wiring diagram its the red/black wire going in to the instrument panel
Click image to enlarge this should help you. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
15th Feb 2009 2:14pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
The speed signal on the puma is not CAN, its a normal analouge 12v PWM signal from the speed sensor on the transfer box, i think if my memory is correct its 5200 pluses per mile.
The CAN part of the speed signal is only used from the instruemnt cluster to the engine ecu. Regards Pete |
15th Feb 2009 11:19pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
I asked the same question, when the Puma came out,, but never bothered to wire in the speed sensor,,
Unit works fine on mine, without it California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
15th Feb 2009 11:32pm |
KPNuts Member Since: 21 Jan 2011 Location: Near Bedford Posts: 45 |
Guess splicing into the red/brown wire would also work for fitting a sensor http://www.devon4x4.com/index.php?page=sho...;Itemid=14 for a brantz trip meter (see my other post http://www.defender2.net/forum/topic5199.html?highlight=).
Can anyone confirm? Thanks Keith 2010 110 Utility Station Wagon 1996 110 Station Wagon |
24th Jan 2011 10:20am |
For my Becker Cascade Pro I taken it from the instrument pannel connector pin13 C1040
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
24th Jan 2011 7:44pm |
Thanks for confirming. Sensor ordered.
Where did you cut into the wire? I have the instrument pod out now and there is not much exposed wire between the connector into the pod and the wrapped loom. Is there a more accessible length of this wire somewhere else? Thanks Keith 2010 110 Utility Station Wagon 1996 110 Station Wagon |
29th Jan 2011 2:29pm |
But you don't need the interface! Only an "Y" connection! I had take off the connector, sold a tiny cable on pin 13..... Thats all. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Jan 2011 7:18pm |
robertgoulet Member Since: 24 Nov 2016 Location: Berlin, Germany Posts: 2 |
Hi guys,
I have been reading this thread but things seem to be different in my 08 TD4.. When taking off the instrument cluster, I have three black/red wires and no brown/red wires. Does anyone know which is the correct one? Thanks a lot, Robert Click image to enlarge Click image to enlarge |
24th Nov 2016 5:25pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 |
Wow that's thread revival!! James
24th Nov 2016 6:03pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Maybe
This is the location of the wire used for the speedo pick up when fitting cruise control. Click image to enlarge Cheers, Kyle. |
24th Nov 2016 9:59pm |
Hi Alien,
Thanks! But how can I find out which of the cables enters #13? It is not visible from the back of the connector as they enter it in a big bunch... Is there a way to test this? |
24th Nov 2016 10:52pm |
From memory I removed the cover from the back of the plug.
I did mine @18 months ago but it looks black in your picture. The wires will not fall out of thier respective positions when removed. The other method is to probe one of the wires and use a ohm meter to test for continuity to pin 13. You have a 1 in 3 chance of getting it right first time doing it this way. Cheers, Kyle. |
24th Nov 2016 11:02pm |
