Home > Puma (Tdci) > Differential Oil Specifications |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2416 |
80W/90 or 75W/90 synth or mineral, and always GL-5 Puma 110" SW
15th Jun 2017 12:12pm |
Emile Member Since: 17 Jun 2016 Location: Cadiz Posts: 14 |
MK thank you very much for your reply. I always learned that synthetic and mineral should not be mixed, any idea which oil was put in at the factory? It will be the first time for me changing the diff oil so genuine should be in there.
15th Jun 2017 2:53pm |
Both oils are mineral based and in any case sure you can mix synth with mineral (most are Group III or IV and PAO blends). Besides there is very little oil left after you drain the diff. Puma 110" SW
15th Jun 2017 3:06pm |
