Home > Tdi > Bulkhead removal bar kits? |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 918 |
Hi.
Yes I have fitted one of these. It was a good few hours work but the results were worth it. *It is much easier to do with the roof removed. * There is a fair amount of mess made so a workshop vacuum cleaner is handy. *A angle grinder with a few 1.0mm 'Plasma' blades makes for easy cutting *then using a carbide 'Flappy wheel' takes off the sharp edges. *Measure thrice cut / drill once. *Lr build tolerance means the bar is a easier fit if you engage all the bolts first then progressive tighten them down. After the bar creates a better seat position if you are of that tall persuasion and IMHO the cabin felt much more spacious and reaching stuff in the back was fair easier. |
15th Jun 2017 7:21am |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 |
My Puma has this from the factory. Did all Pumas have it or was it an optional extra?
15th Jun 2017 8:11am |
ukmiitchellx Member Since: 04 Jan 2017 Location: Cornwall Posts: 27 |
I'm about to do this job this weekend and was wondering whether a reciprocating saw would do the job as opposed to a grinder as I think it would be less messy! 1995 300TDi Hardtop Nato Green
15th Jun 2017 8:39am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Can you post up the method on here when you do with pics, so I can see what im getting myself into? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
15th Jun 2017 5:20pm |
Can Do! Basic plan is: remove roof and sides, remove front seats and cubby box, cover windscreen and set to with cutting implements 1995 300TDi Hardtop Nato Green
15th Jun 2017 6:53pm |
Any update?
Still on my list of "might do" things 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
13th Aug 2017 10:46pm |
