Home > Td5 > Reverseing gear electrical pick up point in cab
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
I'm installing a reversing camera, to save time I went for a wireless one thinking it would save on wiring from back to front, but the wiring instructions still asks for a reversing gear electrical pick up point for the camera on my dash, any idea guys?
Keith 2005 TD5 90 CSW XS
Post #630999 13th Jun 2017 8:56am
VeeTee
Netherlands
What about the reversing light, which comes on when you select rear gear? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #631000 13th Jun 2017 9:10am
rallysteve
You will need to pick up the wire from the reverse light switch in the side of the main gearbox. You should be able to access this from the panel beneath the centre seat/cubby box.
There is no reverse light wire inside the cabin sadly.
Post #631001 13th Jun 2017 9:11am
bankz5152
I would run a cable from the reverse light into the dash, that or as above the gearbox but that may be tough to get to and make sure you do a good job of sealing it up as it is exposed!
Post #631008 13th Jun 2017 9:29am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You can pick it up at the bulkhead connector just below and behind the expansion tank, you just need to tap into the wire there and run a wire through the bulkhead grommet into the dash.
It's normally the orange multi-plug and you're looking for a green/brown wire.
 http://www.yorkshireoffroadclub.net/
Post #631019 13th Jun 2017 10:16am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
On my setup, the loom that came with the camera had an extra wire. One at the camera end and one at the screen end. I literally joined that extra wire to the screen positive at that end and then the opposite extra wire to the camera live - which then joins the reverse light live. So, when you select reverse, the power goes to the reverse light and then camera and back through the loom to power the screen. I have only needed a ground at the screen end.
Not sure that makes sense without a picture
EDIT: I just pinched Butcher Boys picture from his thread here which covers similar; http://www.defender2.net/forum/topic54967.html
So on the picture above, I connected the extra wire A to the screen positive. Extra wire B was to the camera positive and then piggybacked the reverse light positive.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  TD5 Defender 90
Discovery 3 HSE
Post #631043 13th Jun 2017 11:49am
rallysteve
I believe the OP bought the wireless system through to prevent the need to run any wires.
Post #631081 13th Jun 2017 2:51pm
Kent_keith
Sorry guys for the late reply, I'm still working on this as I'm finding a good position for the camera almost impossible to achieve, I'll continue tomorrow and let you know the outcome, thanks for all your replys.
Post #631155 13th Jun 2017 6:53pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Keith, two best positions for a camera are (one) under the licence plate lamp and (two) in the rear cross member area for the trailer wiring plug (assuming no plug there). I have installed in both these areas. As for light and camera trigger wires I have always used the rear back up light positive wire.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #631224 14th Jun 2017 12:49am
