![]() | Home > My Defender > Alan |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
Well I still have the front shocks to do.. I've had a quick drive over the local speed bumps and the rear end damping is much improved.. I'm thinking I might get a swing away spare wheel carrier as I have noticed the back door is heavier with the new wheel...
![]() The paint that is the nearest in colour was mixed from the same paint code as the other, not made from analysis of the existing paint, don't know why they are so different. I think some big Halfords can analyse your paint to get a match... Any nearer to that MOT yet? 👍 1993 200Tdi Defender 90 |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 ![]() ![]() |
that's one of the things I am going to fit before I even consider changing the wheels, Is a swing away for the door. My dad said its best to fit 1st, to at least save the rear hinges, with the weight of the spare wheel. My rear door does need a good overhaul with the electrics and a bit of panel repair work, plus a replacement door card. So we are looking close to 300 quid to fix the door.
I am going to put it in for MOT this week, while its still got one on, then we will going to go from there. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Which wheel carrier are you going to get? I like the Nakatanenga one but not keen on the price
![]() I put a Mud rear door card on.. I have the other I took off, it's ok if you want it? I don't want anything for it, it has the wiper cover and the bit that covesr the bottom door stopper... 1993 200Tdi Defender 90 |
I am looking at the mantec unit for her, also i am after a mud door card too. just to beef up the rear door. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
I have finished the front shocks.. I managed to do it without needing to change the turret rings thankfully.
Whilst the Air cleaner housing was off I gave it a good clean, rub down and a few coats of paint. ![]() Click image to enlarge 1993 200Tdi Defender 90 |
I like that
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks Darren.. I haven't done much in there yet either apart from some silicone intercooler hoses..... theres is a bit of rusty pipework and brackets going on that I'd like to do something with. As the air cleaner housings are now an obsolete part and expensive s\h I thought I'd best look after it.
Enjoying your thread ![]() |
That looks like new! I need a new bracket to keep mine on, I seem to have a bodge repair. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
I will give you a heads up on the Knocky rear end. My dad had the same trouble, you are going to need to replace the Bushes on the rear radius arms. My dads just polybushed his and all is nice and quiet now. ( best get a garage with a press to do that for you) My dad made a right hash and a half getting the metal sleeve out.
![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
"Knocky rear end"... not me
![]() today I repaired a corroded wire on the central locking.. and fitted a missing bracket that the grill fastens to and then fitted this item of beauty... ![]() |
![]() My build thread http://www.defender2.net/forum/topic17615.html |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
Looking good
Looking great!
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 ![]() ![]() |
Thats looking great
