Home > My Defender > Defender 90 LS/6L80 conversion. step by step! |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 |
Did you source your adapter from Marks4wd? Thanks Andy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Working towards Carry on camping! |
9th Jun 2017 6:56am |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
Hi Andy,
No, Nick Markiw at Rover works in the US Rgds Peter 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
9th Jun 2017 7:34am |
Thanks Peter Working towards Carry on camping!
9th Jun 2017 9:54am |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 496 |
Hi Peter,
I would be interested in the spreadsheet if it wasn't too much hassle . Savage build and attention to detail Shane |
12th Jun 2017 8:02pm |
Hopefully this works...
https://www.defender2.net/gallery/albums/u...0PETER.xls I would allow probably about $1k for stuff I have missed / forgotten, but that's pretty complete/accurate 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
12th Jun 2017 9:18pm |
Thanks Peter. Will have a read through in work tomorrow
13th Jun 2017 8:46pm |
No worries Shane,
If you have any questions let me know. Cheers Peter 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
13th Jun 2017 10:13pm |
Had this stop a couple of times. Diagnosed it in the car park at the pub with a faulty ignition switch. Luckily I had a couple of tools on me (philips screwdrivers and multimeter) and could remove the instrument panel. The riveted connection on the switch that holds the terminal is loose. wobbling it resulted in it starting straight away both times
I have a new one on order and it should be with me tomorrow. Cheers Pete 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
19th Jun 2017 4:48am |
Slight update on this as its been a while!
I have fitted a much larger radiator, and a lower temp thermostat and 2 high flow fans. Click image to enlarge That has required some mods to my front bumper due to how far back my high mount sat but I haven't started on that yet so I just took the winch out in the interim. 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
24th Oct 2017 7:12am |
outbackjack Member Since: 07 Apr 2018 Location: Darwin Posts: 4 |
Great build. I have sent you a PM with a few questions.
7th Apr 2018 2:42pm |
Nath2023 Member Since: 28 Nov 2023 Location: Brisbane Posts: 1 |
Hi I’m not sure if it was covered however who did the engineering approval and what did you if anything have to do re emissions?
Thank you |
28th Nov 2023 11:33am |
