Home > Maintenance & Modifications > Front Grille
Wheel
Front Grille
Hi All,
I have an issue with my front grille, the one below the plastic one which I'm not impressed about on a 2 yr old vehicle.
The paint has come off and it looks like the grille was oxidised + has flaked off.
I've heard of this before and think I've read about it on here but has anyone experience of it and what was the outcome re;warranty as mines in for its second service on Fri and I'll be "discussing" it with them ??
Thanks,
Mark
Post #629713 7th Jun 2017 5:34pm
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
The service people at the squeeler will say its not up to them, as LR have to approve all warranty work but for something like that you should be fine. I called in to my local one to ask about having rusty bolts replaced. They said it shouldn't be a problem but LR have to ok it.
There's no point in asking why its happened its a defender!! Rolling with laughter The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #629714 7th Jun 2017 5:38pm
JOW240725
You should get it resprayed by LR under warranty. Or just bite the bullet and get a stainless steel grille Thumbs Up James
Instagram @suffolk_rovers
Post #629751 7th Jun 2017 7:45pm
Siwynne
Mine was repainted under warranty
Post #629762 7th Jun 2017 8:15pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Had this happen on both my defenders, and both sorted by the dealers under warranty without fuss 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #629779 7th Jun 2017 9:18pm
Wheel
Thanks All,
It's sounding encouraging and i'll let you know how I get on
Depending whats said I'm thinking of either getting a stainless one, getting mine powder coated or making a mesh one as I have a fine mesh behind my main grille
Mark
Post #629789 7th Jun 2017 9:31pm
mse
Mine is being repaired as we speak Mike
Post #629794 7th Jun 2017 9:48pm
zsd-puma
The problem is they seem to make this grille from the cheapest ally they can, so i think there's little point getting your existing one powder coated, as it'll likelly only last another couple of years. There are stainless ones available both in bare stainless or powder coated black.
I fitted a cheap Britpart stainless one, it's fine.
Post #629796 7th Jun 2017 9:55pm
Vitesse
During manufactiure, the grille is fitted to the surround in bare aluminium. It is then painted attached to the front panel
The bare aluminium that is hidden then corrodes. I agree with others on here and fitted a stainless grille after mine flaked at about 18 months Problem sorted. Thumbs Up
I expected if the original grille was well painted first and then fitted, it might last a bit longer IMHO
Brian 2015 90 XS Santorini Black
Post #629813 7th Jun 2017 11:33pm
Rallymental
So instead fitting the stainless one is it better to strip the original aluminium one, acf it and leave it bare? The definition of insanity is doing the same thing over and over again but expecting different results.
Post #629814 7th Jun 2017 11:48pm
zsd-puma
stainless is very much fit and forget.
Post #629815 8th Jun 2017 12:34am
agentmulder
Kuwait
I just scraped/cleaned mine the lower grille and resprayed (out of warranty, third owner...)
Easy job, looks good. Solved the bowel problem, working on the consonants...
Post #629816 8th Jun 2017 4:17am
josefk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
just one small consideration - I had mine done last year under LR warranty and wished I hadn't bothered.
its now sprayed "of a piece" with the surrounding fascia so if and when the grill part corrodes again (and I would like to replace it with stainless or whatever) I'm going to have a bigger mess to clear up rather than a simple grill only replacement.
I hadn't anticipated they would spray it like that but it makes sense seeing as its riveted rather than screwed so arguably for a paint shop "one part"...
---edit--- just read Vitesse' post above - maybe I hadn't properly noticed it was painted as an assembly before the warranty work. It is certainly quite a "thickly" painted assembly after it...
cheers
Post #629919 8th Jun 2017 11:36am
Matt-B
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
I've just bought a stainless mesh one, I intend to fit this weekend, I couldn't be bothered with the hassle of getting it done under warranty, and then it happening again in a couple of years, I've done the same with the windscreen blocks and got some CNC'd alloy ones, hopefully I'll fit them and not have to worry about it again.
Post #630123 9th Jun 2017 8:24am
Balvaig
Very much a personal choice. Rather than the hassle of a warranty claim, and the 70 mile round trip to the dealers, on my last Defender I rubbed it down and sprayed it satin black, as a contrast to the orkney grey grill.
The latest Defender was Dinitrol'd from new at the back of the lower grill. I also did all the internal grill fixings with clear Dinitrol too. Learning from previous experience Very Happy
Post #630129 9th Jun 2017 8:56am
