Home > Maintenance & Modifications > Puma/tdci front seats on tdi rails? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
I think the design remained the same from 1989 on 2002 90 Td5 Station Wagon
7th Jun 2017 8:22pm |
front seats should be a straight swap however you do it.
What do you mean by rear tip up ones? Forward facing ones in the boot will need a bit of work, as the wheel arches are stepped on Puma's but it's not impossible. 2nd row will fit a 110 with a bit of fettling to the brackets at the sides (which the back of the seat sits on) as the angle on the front of the wheel arch is slightly different i think. Obviously you'll need the central floor mount bolting in too. |
7th Jun 2017 10:01pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Ahh they're actually from a late Td5 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
7th Jun 2017 10:12pm |
