Home > Maintenance & Modifications > Puma/tdci front seats on tdi rails?
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Does anyone know if puma/tdci front seats will bolt straight onto my 200 tdi seat rails?
I'm assuming rear tip up seats will fit fine? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #629764 7th Jun 2017 8:19pm
grafty99
I think the design remained the same from 1989 on Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #629765 7th Jun 2017 8:22pm
zsd-puma
front seats should be a straight swap however you do it.
What do you mean by rear tip up ones? Forward facing ones in the boot will need a bit of work, as the wheel arches are stepped on Puma's but it's not impossible.
2nd row will fit a 110 with a bit of fettling to the brackets at the sides (which the back of the seat sits on) as the angle on the front of the wheel arch is slightly different i think. Obviously you'll need the central floor mount bolting in too.
Post #629801 7th Jun 2017 10:01pm
Kit
Ahh they're actually from a late Td5 Embarassed 1993 200 Tdi 90 CSW
Post #629804 7th Jun 2017 10:12pm
