Home > Maintenance & Modifications > Vented brake discs |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3745 |
Hello
My 110 needs new pads and the discs are low. While I get the pads changed I'm thinking fit some discs also. Std Discs (rear) appear to be around £30 a pair. Just been on John Craddock and vented, drilled and grooved would be £100 a pair. so £70 more. however I guess with my mileage should last a good few years,.. Is there any? benefit in getting these over ordinary ones? I;ve had high performance cars that have had these in the past but this is a truck... albeit a heavy one. I am thinking of getting the remap and oil cooler etc soon https://www.johncraddockltd.co.uk/accessor...59807.html Thanks |
5th Jun 2017 2:26pm |
Don't you need different callipers to go from standard to vented discs, as they're thicker? Darren
5th Jun 2017 2:54pm |
^ No idea? but if anyone knows
5th Jun 2017 2:59pm |
^ saves me £70 also
5th Jun 2017 3:08pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2639 |
If your 110 is newer than 1994 or so it should have vented front discs as standard. Rears will be solid, and there will be no benefit to converting to vented.
Drilled/grooved are a waste of time in my opinion also. It's not like you're going to be driving it like a racing car. |
5th Jun 2017 3:52pm |
Some do. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
5th Jun 2017 4:11pm |
I can bob on it it but find the std brakes with std engine fine.
Will keep standard |
5th Jun 2017 7:39pm |
