Home > Puma (Tdci) > 2.4 Puma three amigos. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
just be careful the ABS system altered between 2010 and 2011 DEFENDER 90 TDCI XS,
2nd Jun 2017 5:35am |
(Shuttle valve switch) and electrical malfunction fault codes (4016 / 114 / 134) are often found when scanning with diagnostics.
new replacement ABS unit £ 20111 plus VAT |
2nd Jun 2017 8:11am |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Can be bought for much less.
2nd Jun 2017 9:22am |
I should hope so. |
2nd Jun 2017 12:10pm |
slip fat fingers on the phone LRJ £ 2,011 plus vat |
2nd Jun 2017 12:13pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
It changed to a Bosch unit at that time, integral electronics so very different from the Wabco unit fitted up to then. |
2nd Jun 2017 2:00pm |
Maris Widgeon Member Since: 11 Dec 2013 Location: Cotswolds Posts: 216 |
Had the same issues with my 07 truck , once they came on I could clear the fault code then they would return immediately.
I replaced the shuttle switch it made no difference. Took it to a guy I know who is a " real" mechanic and he said he would take it apart to have a look before I go and buy a new one . My problem was the small bearing on the bottom of the pump motor was seized as it had been sat in rusty water . The bearing was matched up at a local supplier for £1.50 , and all put back together (not quite as simple as that ) and it worked better than ever before. That was 2 years ago and 25,000 miles and all seems to be well . I wouldn't be able to have done the repair but it is able to be stripped down , if it is going to be binned anyway maybe worth a look. Nick |
3rd Jun 2017 3:46pm |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 92 |
Hello Maris, do you have the part number that was replaced? I'm with the same problem !!!!
regards |
25th Oct 2017 10:04pm |
The guy just took the motor and old bearing to a local bearing supplier (for internal and external measurements) they managed to match it as most bearings are usually patern sizes. We used a supplier who just deals in "belts and bearings" mainly for agricultural kit.
Sorry couldn't help with a part no. everyone said it couldn't be fixed !!! Nick. |
26th Oct 2017 8:21am |
