Home > Puma (Tdci) > 2.4 Puma three amigos.
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
My late 2007 2.4 has a fault i think iside the Wabco ABS pump and i can source a 2010 2.4 unit. Will they be compatible and what is involved in changing?
Thanks.
Post #628309 1st Jun 2017 8:32pm
LR90XS2011
just be careful the ABS system altered between 2010 and 2011 DEFENDER 90 TDCI XS,
Post #628358 2nd Jun 2017 5:35am
dorsetsmith
(Shuttle valve switch) and electrical malfunction fault codes (4016 / 114 / 134) are often found when scanning with diagnostics.
new replacement ABS unit £ 20111 plus VAT
Post #628377 2nd Jun 2017 8:11am
Lightningtweeds
Can be bought for much less.
Post #628390 2nd Jun 2017 9:22am
zsd-puma
I should Censored hope so. Laughing
Post #628448 2nd Jun 2017 12:10pm
dorsetsmith
slip fat fingers on the phone LRJ £ 2,011 plus vat
Post #628449 2nd Jun 2017 12:13pm
Fifth Horseman
It changed to a Bosch unit at that time, integral electronics so very different from the Wabco unit fitted up to then.
Post #628482 2nd Jun 2017 2:00pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Had the same issues with my 07 truck , once they came on I could clear the fault code then they would return immediately.
I replaced the shuttle switch it made no difference. Took it to a guy I know who is a " real" mechanic and he said he would take it apart to have a look before I go and buy a new one .
My problem was the small bearing on the bottom of the pump motor was seized as it had been sat in rusty water .
The bearing was matched up at a local supplier for £1.50 , and all put back together (not quite as simple as that ) and it worked better than ever before. That was 2 years ago and 25,000 miles and all seems to be well . I wouldn't be able to have done the repair but it is able to be stripped down , if it is going to be binned anyway maybe worth a look.
Nick
Post #628693 3rd Jun 2017 3:46pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Hello Maris, do you have the part number that was replaced? I'm with the same problem !!!!
regards
Post #659699 25th Oct 2017 10:04pm
Maris Widgeon
The guy just took the motor and old bearing to a local bearing supplier (for internal and external measurements) they managed to match it as most bearings are usually patern sizes. We used a supplier who just deals in "belts and bearings" mainly for agricultural kit.
Sorry couldn't help with a part no. everyone said it couldn't be fixed !!!
Nick.
Post #659720 26th Oct 2017 8:21am
