Home > Technical > coolant bother - number 10009485937
Jonathan111
OK - having spent a fair bit of time researching this, PLUS LR specialist did a 20psi test on coolant system, the level on the e-tank still falls every drive and generally 2cm every 100 miles. So : if its the P-gasket, no sign of the tell tale residue (but that is from IAT coolant era posts - ie, coolant had siiicate which would leave a trace on evaporation, now - mine with OAT, unlikely to be residue on area? I am intending to test the OAT to see if it leaves a trace). Anyway, where is all this coolant going? cheers, J
Post #627867 30th May 2017 9:45pm
mk1collector
Have you replaced the coolant reservoir cap? The seal can go on these and leak out when hot. Cheap to buy just to rule it out. Ray
My build thread
Post #627868 30th May 2017 9:56pm
Normal characteristic, nothing to worry about.
Replacing the cap would be a good idea all the same. $W33T $0U7H3RN $UG4R
Post #627872 30th May 2017 10:08pm
Mo Murphy
Erm, I beg to differ Steve, losing that much coolant is certainly not a normal characteristic, it indicates there is a problem. No engine routinely loses coolant at that rate !
50 Shades of Pennine Grey
Post #627874 30th May 2017 10:33pm
Jonathan111
thanks all, it certainly is p**ng away a ton of coolant and no obvious egress. I suspect its P-gasket but if so, would expect to see trace, my q is whether OAT coolant leaves this trace - suspect, it is only IAT (the old style coolant), because it is full of silicate, which *would* leave a trace - silicate is more or less like kettle scale, so bound to show up when dried on leaking P-gasket.
Post #627876 30th May 2017 10:47pm
For some reason I was thinking 2mm not 2cm. Rolling Eyes Thumbs Up
OAT does leave a trace, depends on colour of your coolant?
I'd be taking a look at possibly split hoses and especially your coolant / Waterpump.
I had issues with the Waterpump gasket on mine, started of not much and got worse pretty fast and coolant isn't cheap to pour away.
Also not good for animals or wildlife if course.
I doubt the radiator is the issue $W33T $0U7H3RN $UG4R
Post #627880 30th May 2017 10:56pm
Jonathan111
thx - will continue to research, the stuff is going somewhere, that's for sure!
Post #627882 30th May 2017 11:01pm
ericvv
Not sure I understand that even loosing 2mm in the expansion tank every 100 miles would be normal. I think only normal is that nothing gets lost, period. It is a closed circuit. I hope it is just the so often blamed cap here. I never lost a drop so far in 9 years.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #627884 31st May 2017 3:53am
On three occasions I have suffered from coolant loss at rates approaching those you describe.
  • First was a defective expansion tank cap.
  • Next was a leak from the front seal of the water pump (the coolant then escapes from a drain hole in a really hard to see location underneath the pump and can only be seen from underneath).
  • Finally the radiator itself was leaking and squirting coolant onto the fan, whcih then distributed it so effectively over such a large area that no residue was visible. The dark patch on the radiator was the only symptom.
Post #627894 31st May 2017 7:35am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I assume as you mention the p gasket your engine is a 300 tdi?
If so another source of leak might be the expansion tank itself. The original black ones had a habit of splitting a side seam and leaking out there.
Post #627912 31st May 2017 9:16am
Jonathan111
belated thanks to all for posts on this, there's a new development, which I'll start a new thread on, many many thanks to all, cheers, Jonathan
Post #632070 18th Jun 2017 11:03am
zsd-puma
OAT still leaves staining, it's usually pink. The problem is the viscous fan disperses any leak so the staining isn't so obvious.
On a side note, you know you don't get charged by the letter for posting on here? e-tank, p-gasket..... Laughing
Post #632081 18th Jun 2017 1:46pm
mse
I had a leak in a 300tdi - took ages to find, pressure tests running etc etc etc.
Turned out to be a slight leak from the top radiator hose connection - adding a 2nd jubilee clip solved it. It only was noticeable when hot, and by chance i lifted the bonnet after a long drive with the engine on to do something else and found it.
Cant tell you how many times it had tests, inspections etc...as it was dripping onto things it wasnt noticeable and didn't leave any tell tails! Mike
Post #632090 18th Jun 2017 4:00pm
