![]() | Home > Puma (Tdci) > How long to idle motor before switching off? |
I still give her at least 30 secs after reaching the final destination just old habits
No need to these days, just turn it off.
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Leave mine for about 10-15 seconds - I think the manual suggests it? Defender 110XS SW gone... now VW California 180 4 Motion.
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
I idle the Audi for about a minute or so.
I always idle the landy until the EGT has come down to 160C. Sometimes it takes 1min, sometimes it takes 4min, depending on how hard you have been driving. I suggest you get an EMS like the MadMan, it will show you how to drive according to EGT, which will prolong your engine's life. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Puma90man Member Since: 27 Feb 2011 Location: South Africa Posts: 26 ![]() ![]() ![]() |
Thanks guys !
I will rather be cautious as I am planning to stick to this vehicle as a toy until death do us part Need something to work on when I'm 94 |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Reason is if you switch the engine off while the turbo is still spinning you loose oil pressure to the turbo resulting in the bearings running dry.
Depends on what you've been doing.
My house is on a de-restricted road so I arrive home at highish revs. I always let it tickover for atleast 30 secs. On the other hand if I've spent a couple of minutes tootling round the supermarket carpark I don't bother to wait. |
The oil pressure drop on switch off and the short time the turbo spins does not let the bearings run dry. If it kept spinning for 10 minutes then sure, but it doesnt. |
It's mainly to let the turbo cool down.
At high temprature it could vaporise the oil. |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
They said do this ten years ago but I never did on my SAAB, it used to get thrashed and did 177,000 miles on the original turbo. On other cars apparently if it has an inter cooler it is OK to switch straight off after being worked.
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Td5 owners manual states 10 secs, otherwise possible damage to turbo through inadequate lubing of the turbo bearings.
Surely simple answer is look it up in your Puma manual and draw your own conclusion from that ? Just for the record - as no self respecting bloke ever reads any manual.. ![]() ![]() ![]() |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
usually about 10-30 seconds, i use the time to gather my stuff and put the disklok on.
puma110 Member Since: 28 Feb 2011 Location: Australia Posts: 7 ![]() ![]() |
It depends a lot on what the engine has been doing just before you're planning on turning it off. If you've been taking it pretty easy then a short time will be fine. But if you live on a steep driveway and have been giving it a bit to get up or revving hard even for just a shortish period of time then a minute or so minimum is a good idea to get the temperatures back down. It's not all about lube for movement of parts, but more about cooling. Without any lube flow or air flow or rotation the high exhaust temps can overheat bearings and warp bits of metal that aren't meant to be warped.
The manual states:
