Home > Maintenance & Modifications > Raptor Bedliner
arran jones
Raptor Bedliner
Hello All,
I am thinking of buying 4litres of Black Raptor bedliner to protect the rear tub!
And to save cost I'm wondering about rolling it on myself!
Has anyone used this and does anyone recommend it
Many thanks
Arran
Post #627254 27th May 2017 7:24pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
If its just for the rear tub then it's okay but bear in mind it goes off quite quickly and becomes sticky, its easy to touch up later if you miss bits though 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #627255 27th May 2017 7:35pm
JOW240725
I have some on order just waiting for delivery. I'm going to roller/brush but only inside of a trailer so finish not critical. I'll let you know how it goes but it might be a few weeks before it gets done! James
Instagram @suffolk_rovers
Post #627256 27th May 2017 7:37pm
arran jones
OK thanks both
Kit, how long does it stay sticky for
And the Base of the rear tub does it need sanding down and a spray of etch primer before I roll the Raptor on or do I just roll it straight onto the normal metal floor
Post #627259 27th May 2017 8:01pm
Blanc
I've used this but with a cheap shutz gun on a small cheap compressor (from Aldi)
The finish is spot on and the paint is good.
I've not rollered but consider the modest investment to get a consistent good finish.
David.
Post #627266 27th May 2017 9:04pm
arran jones
OK, can u get it smooth with a roller /brush
Also before applying it, do I have to mix the hardener in with the main Raptor if so how much hardener do I put in.....?
Thanks Thumbs Up
Post #627311 28th May 2017 8:48am
Kit
arran jones wrote:
OK thanks both
Depends on how warm the day is but you've got about 2 or 3 mins before it will start to become an issue, I think this product is more designed to be sprayed if i'm honest.... I would follow Blancs advice if you want a really nice good finish (it'll still be okay with a roller though).
The instructions that come with it are pretty good and answer all the questions you've asked? 1993 200 Tdi 90 CSW
Post #627314 28th May 2017 9:14am
m666blp
United Kingdom 2000 Defender 110 Td5 DCPU Aintree Green
[/url]https://www.youtube.com/watch?v=MKzhSHpebos
I am doing my chassis and rear tub at the moment . Its dead easy . Better finish with a Shultz gun at app 60psi than with a roller .
Post #627322 28th May 2017 10:19am
arran jones
Blanc,
Just looking on the Web, is it just a small portable air commpresser I need, have you got a link of the one u brought?
Thanks Thumbs Up
Post #627333 28th May 2017 11:03am
m666blp
You can get a little compressor from machine mart for about £100, you will need a hose/ gun too. Budget £150 at least but you do get what you pay for .
With Raptor the lower the Psi the rougher the finish / texture, a little compressor may struggle to hold a higher Psi for long periods of time.
I have seen good finishes achieved with a roller, a gloss roller will give a more uniformed texture for sure.
Post #627347 28th May 2017 2:15pm
arran jones
OK thanks guys,
I'm gonna crack on with this, I've got friends that work for a paint company so I might see if I can borrow there compressor and hose for the day, and I'll get the Raptor off flatdog and also the shultz gun, I guess that the gun attaches on to the hose and the other end of the hose attaches onto the Raptor or is that wrong... Whistle
Post #627358 28th May 2017 3:03pm
m666blp
Hose attches to compressor - Other end of hose to gun - Raptor screws into the shutz gun pick up pipe. You may want to get a pressure valve fitted to the bottom of the gun so you can set the psi for you required texture finish .
If you watch the video I posted a link to or just search U-Pol Raptor on You tube there are heaps of tutorials.
Post #627362 28th May 2017 3:13pm
m666blp
You will need to rub it down with a scotchbrite pad or 180 grit sanding disc , Any bare metal with need an acid etch primer on it also.
Post #627363 28th May 2017 3:21pm
JOW240725
Steel needs a primer (like Buzzweld RCP), aluminium needs an etch primer. Both keyed in by scotchbrite rub down first. James
Post #627371 28th May 2017 4:11pm
arran jones
As it's a truck cab and will eventually be putting the canvas set back on, I'm probebly gonna do it b4 I put it back on, does it matter if the Raptor coating covers over the bolts etc or do I just put tape over them?
Post #627397 28th May 2017 6:17pm
