![]() | Home > Maintenance & Modifications > What cable for HID's |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
14 or 16 gauge would do it. Puma 110" SW
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
Of which type? Thinwall, Silicone, regular auto.
Dia isn't so much the issue but the dielectric strength of the sheath to safely contain the voltage. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
I used regular auto for 55W ballasts. Protected with plastic tubing. Puma 110" SW
Okay, thank-you MK.
Not quite so much to worry about as I thought then, I'll be using Superseals for connectors and PVC tube and heatshrink to seal ends. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
