Home > Defender Celebration Series & Classic Works > Paint starting to flake -110 Heritage
Huttopia
After 18 months the paint is starting to flake around the bottom of the windscreen rubber on the drivers side. There is a very small vertical joint on the face of the bulkhead and that appears to be the source of the problem. Off to Listers in Droitwich for some warranty work........ Good to know that the run out models didn't get any special treatment and shipped with the same crap finish as every other Defender!
Post #622806 9th May 2017 8:25am
Caterham
Feel for you.
It's diabolical really. The defender could so easily have been some much more / better. Crying or Very sad
Post #622807 9th May 2017 8:35am
Gravygraham
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Think I'll pop out to the garage and check mine . . Lucky custodian of several Landies
Post #624983 17th May 2017 10:08pm
JOW240725
It is shocking but hopefully LR will get it resolved promptly! James
Instagram @suffolk_rovers
Post #624985 17th May 2017 10:12pm
Martin
Site Admin
Re: Paint starting to flake -110 Heritage
Good luck with that... I've been waiting over 3 months for them to get back to me about warranty paint work (yes I've chased them). Maybe they're hoping it'll repair itself Rolling Eyes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #624986 17th May 2017 10:15pm
Stacey007
Its bad but as other have so not matter how much the last ones were in each variety they were no better put together than a farm special with steels and pick up back.
They leak, rust, but we sill bought / buy them Smile
Hope you get it sorted though Thumbs Up
Post #624987 17th May 2017 10:16pm
ericvv
Martin, do we need to give you the contact details of Amellia of LRCR on here? Whistle You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #625014 18th May 2017 6:14am
LR90XS2011
mine had this problem when nearly new was fixed under warranty and has not reappeared Thumbs Up DEFENDER 90 TDCI XS,
Post #625015 18th May 2017 6:16am
Huttopia
Well I've sent them a picture below which hopefully is pretty clear. It looks to me as if moisture has worked its way in due to the poor join / split. It goes in the week after next for this and to investigate a leak from the rear of the gearbox. If it was a simple as just using the landy what would we all do with the spare time.... I'll keep you posted!
Post #626750 25th May 2017 7:32am
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
That looks pretty poor for 18 months old, do you keep her under cover? Mrs Doublea's 2013 90 had just slight bubbling at the corresponding top seam after about 2 years, but was always garaged. I think that the windscreen frame was simply repainted but I'm sure I've read on here about the frames being replaced. Standard warranty fare in any event.
Is that rust/stone chip damage below or fly splatter? Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #626910 25th May 2017 11:02pm
YOLO110
Australia
That is awful! Shocked
How long is the 'corrosion warrantee' valid for anyway? YOLO... You Only Live Once...
Post #626916 25th May 2017 11:27pm
Jonnyfive
England 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
6 years.I have an 11 plate which I bought in December last year, I noticed corrosion on the windscreen frame and around the alpine roof Windows after I've cleaned it a couple of times, car dealer done a good job is hiding it!! So the beginning of March I took it to local landrover dealer to be told it won't be covered as I don't have all the stamps in my book for corrosion, not happy took it to next local Dealer who took picture and sent them off to JLR and with in a week JLR had accepted responsibility, I had a new windscreen frame and window blocks and the roof sorted out all for free. Now I spray AFC 50 every where!
Post #626923 26th May 2017 6:09am
Huttopia
It's garaged and has been from new. The red marks are fly splatter!
Post #626924 26th May 2017 6:27am
johnp1887
United Kingdom 2009 Defender 90 Puma 2.4 HT Tamar Blue
Anti-perforation warranty is six years from new, and a check is carried out every service at a franchised dealer, the paint flaking/corrosion etc is three years from new, but outside of this JLR may make a contribution depending on several factors
Post #626928 26th May 2017 6:48am
Huttopia
What of you don't have it serviced by a franchised dealer? I'm lost as to what the benefit of the inspection is - its binary, the paint is either flaking or it isn't. This has happened in the last couple of months, so wouldn't have been spotted at the 12 month service window. It feels like more JLR nonsense!
Post #626930 26th May 2017 7:35am
