![]() | Home > Maintenance & Modifications > Where can I find- |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 ![]() ![]() ![]() |
Any decent exhaust shop should be able to do this, simply get them to weld a piece of mild steel in the place of the middle box, should only cost you a few bucks ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Try Alive they are site sponsors
Here http://www.td5alive.com/exhausts.php NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Not a TD5 but the aftermarket exhaust system I got fitted binned the cat, replaced the offset centrebox with a straight through box, and binned the rear box instead! Not sure of the TD5 set up but it does amaze me the different configurations you can get away with!
![]() Treat every day as if it is your last....one day you will be right!! |
