Home > Maintenance & Modifications > Where can I find- |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Any decent exhaust shop should be able to do this, simply get them to weld a piece of mild steel in the place of the middle box, should only cost you a few bucks -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
7th Mar 2011 2:02pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Try Alive they are site sponsors
Here http://www.td5alive.com/exhausts.php NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
7th Mar 2011 2:32pm |
Not a TD5 but the aftermarket exhaust system I got fitted binned the cat, replaced the offset centrebox with a straight through box, and binned the rear box instead! Not sure of the TD5 set up but it does amaze me the different configurations you can get away with! If you go through life with your head in the sand....all people will see is an ar5e!!
7th Mar 2011 3:01pm |
