![]() | Home > Puma (Tdci) > Power to the electric in tank fuel pump. |
test your relay
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
Hi Mr. Smith
I swapped the relay. and expected power on D What i see is the cables go out on exit 2 from the relaybox and come in true the same hole. Than a connector plugs in to the loom that runs to the rear. I expect the driver signal to the relays comes from the ECU and only comes there if it has passed the alarm. Or is the alarm after the relais? |
relay coil signal is + from fuse and neg from ECM only as the 10AS signal go through instilment cluster to he ECM only if you go to start engine is relay pulling in
![]() brown and slat Gray wire (D) runs in loom to fuel pump in the tank if you remove relay and bridge between too brown and slat Gray wires will pump run ![]() |
I found out that it is an earthing problem at the pump side.
Can't find where it is earthed, but I think at the gearbox. Thank you for your help |
C1964-1 right hand side gearbox.
![]() to C0114 fuel pump connector |
Thank you very much!
It was still lose after a transferbox overhaule... I have now to fix the parts I broke!.. Grrr. Regards Q. |
