Home > Puma (Tdci) > Power to the electric in tank fuel pump.
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
I still don't get fuel pressure on my low pressure fuel line. Thought it was the pump so took it out. However it seems no power gets at the pump.
I checked:
The fuel pump relay. It has power and klicks.
F1 15 amp fuse it has power.
At the pump side the brown/white shows no power.
In the box (where the relay's are. I checked the outgoing cable. It showed no power. This is the first cable at the front side. I traced the cable and see it goes out in the second outlet again.
Where is it going? As I presumed it went straight to the relays. But something goes wrong between the relays and this second outlet.
No power on the fuelpump conector. (brown/white)
This is the connector to the second outlet. But it is the incomming power to the first outlet that runs to the rear (fuelpumppower).
Post #626032 22nd May 2017 12:48pm
dorsetsmith
test your relay
Post #626057 22nd May 2017 2:45pm
TopQ1967
Hi Mr. Smith
I swapped the relay.
and expected power on D
What i see is the cables go out on exit 2 from the relaybox and come in true the same hole. Than a connector plugs in to the loom that runs to the rear.
I expect the driver signal to the relays comes from the ECU and only comes there if it has passed the alarm. Or is the alarm after the relais?
Post #626118 22nd May 2017 7:33pm
dorsetsmith
relay coil signal is + from fuse and neg from ECM only as the 10AS signal go through instilment cluster to he ECM only if you go to start engine is relay pulling in Question
brown and slat Gray wire (D) runs in loom to fuel pump in the tank
if you remove relay and bridge between too brown and slat Gray wires will pump run Question
Post #626217 23rd May 2017 7:29am
TopQ1967
I found out that it is an earthing problem at the pump side.
Can't find where it is earthed, but I think at the gearbox.
Thank you for your help
Post #626314 23rd May 2017 12:36pm
dorsetsmith
C1964-1 right hand side gearbox.
to C0114 fuel pump connector
Post #626315 23rd May 2017 12:46pm
TopQ1967
Thank you very much!
It was still lose after a transferbox overhaule...
I have now to fix the parts I broke!.. Grrr.
Regards
Q.
Post #626331 23rd May 2017 1:33pm
