Home > Maintenance & Modifications > Grease with ease.....
Page 1 of 4 1234>
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Greasing the props on Defenders is always a PIA with the nipples in the yokes not accepting grease due to position or the grease gun end being too thick to get on. I discovered that the small chain saw pump gun can get grease in the yokes by pushing the point on to the ball on the nipple and pushing. They are about £8 and are filled manually.
No mess, no waste. 🖒
Post #626099 22nd May 2017 7:15pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Sounds interesting, can you post a pic of an example? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #626113 22nd May 2017 8:18pm
Lightningtweeds
Post #626117 22nd May 2017 8:28pm
zsd-puma
you can get that type of end to fit a full size grease gun too.
Post #626163 22nd May 2017 10:18pm
Lightningtweeds
Maybe but unless you have 3 arms it would be impossible?
Post #626166 22nd May 2017 10:26pm
zsd-puma
Actually i suppose my use of the term "full size" was a bit confusing.
The smaller cartridge type grease guns (Wanner etc) can be pumped with one hand, use the other hand to hold the nozzle on to the nipple. You of course need a flexi hose on the gun.
But you're right with large cartridge guns it's not practical.
Post #626169 22nd May 2017 10:37pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Rolling with laughter Rolling with laughter Rolling with laughter Bow down Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #626178 22nd May 2017 10:50pm
agentmulder
Kuwait
Hrrrm, never had an issue with standard gun on mine..
🤔? Solved the bowel problem, working on the consonants...
Post #626192 23rd May 2017 3:12am
^^ Neither have I.
But then again I always unbolt at least one flange when I grease the propshafts so that I can articulate the joints fully.
Post #626212 23rd May 2017 8:01am
Lightningtweeds
I rest my case M'lud.
Post #626213 23rd May 2017 8:04am
I should perhaps have said "articulate the joints fully in order to ensure proper distribution of lubricant, the way it should be done, not simply to get the greasegun on the nipple".
I have never actually had a problem getting a standard gun on the nipple, although I know that many here do have problems. Perhaps the make and/or quality of the gun makes a difference.
You may find that the press-type greaser won't get grease into a bunged-up nipple very easily.
Another easy option is to replace temporarily the standard nipple with a long nipple that allows the grease gun connector to clear the joint completely. Long nipples
Post #626216 23rd May 2017 8:22am
Lightningtweeds
My rearmost UJ has a nipple in the centre of the yoke with a right angle that is too close to the UJ so how would an extended nipple fit?
Post #626219 23rd May 2017 8:32am
X4SKP
This small 'one handed' Gun...that can be maneuvered around UJ works well
There is an optimum position for the prop shafts, to allow each UJ to be best 'approached'...
when I found this I marked each shaft, so that I can now roll the vehicle into position.
 SKIP
Post #626223 23rd May 2017 8:54am
Retroanaconda
I just used a grinder to narrow the gun nozzle slightly, now it fits between the yokes fine.
Post #626231 23rd May 2017 9:08am
Lightningtweeds
Yip, i done that too but my greasers are too close to the UJ.
Post #626232 23rd May 2017 9:13am
Page 1 of 4 1234>
