Home > Maintenance & Modifications > Grease with ease.....
Page 3 of 4 <1234>
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
I'm sorry for being facetious, but I really have learned about something new, which is good Thumbs Up
But seriously, what do I use this chainsaw for?? Rolling with laughter The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #626358 23rd May 2017 5:08pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Whatever tickles your fancy...
Post #626404 23rd May 2017 7:29pm
mikeh501
I use an air operated grease gun. Pretty much always pops the old grease and gives a good "sizzle" Very Happy
Post #626422 23rd May 2017 8:22pm
Rallymental
Any particular type of grease? The definition of insanity is doing the same thing over and over again but expecting different results.
Post #626507 24th May 2017 1:25am
agentmulder
Kuwait
Mine is a lithium based grease with moly additive.
Rule that hasn't gone wrong for me is to simply go for whatever is the second most expensive one at the local auto shop.
Often that is the one and the same as the most expensive and the least.
Wink Solved the bowel problem, working on the consonants...
Post #626508 24th May 2017 1:32am
Rallymental
Cheers Thumbs Up The definition of insanity is doing the same thing over and over again but expecting different results.
Post #626509 24th May 2017 1:36am
I use Castrol LM Grease (now called Castrol Multi-Purpose Grease), which is an excellent Lithium-based general purpose grease and especially formulated for wheel-bearings. Unless you need a molybdenum-based grease (for example. CV joints and splined shafts) LM is hard to better.
Post #626533 24th May 2017 8:40am
pannawonica
Australia
Every time I chuck the fender on the ramps l'm inclined too pump a little grease into the uj's! Anyhow I just use a standard gun and ordinary flex hose. Yes not the easiest, however far from mission impossible. Thumbs Up Castrol multi purpose is what I use! Thumbs Up Very Happy
Post #626549 24th May 2017 9:54am
pannawonica
Australia
Anyhow was going too say Mr Ford saved a quid! Only four holes tapped for grease nipples on the props, them for uj's and none for the splines. Rolling with laughter Bean counters must have struck again, they sure sucked the guts out of the defender too the end Thumbs Up
Post #626562 24th May 2017 11:06am
Lightningtweeds
Mine came with no UJ nipples on the short shaft that i noticed after 6,000 miles and LR replaced the whole shaft. The long shaft has no hole for the spline nipple and the back yoke has the nipple in the centre.
Post #626563 24th May 2017 11:14am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
This seems to have turned into a public health campaign - check your nipples every year.
Now feel the need to get under mine and count them. Rolling Eyes
Clearly cannot trust the dealers to get it right
Post #626570 24th May 2017 12:28pm
Lightningtweeds
You should have two the car should have six.
Post #626571 24th May 2017 12:40pm
Rallymental
That's 8..... sounds like a cat The definition of insanity is doing the same thing over and over again but expecting different results.
Post #626578 24th May 2017 1:01pm
Roverrobbie
2007 Defender 90 Puma 2.4 HT Keswick Green
Found access to the front u/j nipple was impossible with a 45 or 90 degree nipple. Fitted a 65 degree nipple and no more problems. Available on eBay.
Post #631880 16th Jun 2017 9:38pm
lohr500
I've had one of these for years. Picked up at a car boot sale. It works a treat with a needle point type fitting on the end of a 1ft flexible grease gun hose. No need for 3 hands and easy to deal with propshaft UJs and the like Razz
Post #631918 17th Jun 2017 10:38am
Page 3 of 4 <1234>
