![]() | Home > Puma (Tdci) > Power loss |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Phil,
Sorry to hear about your trouble. Did you ever see any variation in the temperature? Looks like the typical temperature management system that cuts the revs when the temperature going up to ~120°C. Sometimes the problem is not seen in the temp gauge. If you can connect your car to an ODBII check if the temperature is going up over 110°C when the problem appears. Using the search in this forum will gives you some informations about how you can manage the problem (in mine still appears under hot conditions in slopes at high speed). Regards from Chile Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
