Home > My Defender > Proctas Defender 300TDI |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
alternator bearings? My 109 thread
my youtube channel |
20th May 2017 8:00pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5219 |
I am thinking that too, but the alternator looks like its about 2 years old or so, my dad thinks it could be the power assisted steering belt, might need a little tweak, not sure if the 300 is the same as the 200. He says it is.
I thought is it the turbo, but the laugh is it only does it when you are driving but not when its stationary. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
20th May 2017 10:02pm |
any one of the ancillary pulleys, water, tensioner, fan might have dodgy bearings causing them to cease a bit at speed, the belt would then screech over them instead of running nice and smooth. i would whip off ancillary belt and check all pulleys! My 109 thread
20th May 2017 10:42pm |
I will have a look at that, I think I might get the full blown kit for the aux belt, and replace those. Also see about getting the timing belt done too, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
20th May 2017 11:02pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
Awww.. one thing after another Have you narrowed it down yet? 1993 200Tdi Defender 90
21st May 2017 7:21pm |
I haven't been out today, the weather wasn't really 100% for messing about. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
21st May 2017 7:57pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2672 |
Turbo won't kick in properly with the vehicle stationary, it needs the engine working hard to spin it up. Would be worth taking the intake hose off and having a look at the impeller to check the play in it.
300Tdi belt setup is completely different to 200Tdi, being a single poly-v belt rather than several standard belts. A screeching could also be a leaking air hose or intercooler, when pressurised by the turbo under load. |
21st May 2017 8:07pm |
Another thing too i was thinking a boost leak, but it still pulls like a horse. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
21st May 2017 8:19pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
I would think its the alternator as mine made that noise, i'm on my 3rd one now just dont make like they use to
The other thing to check is the belt as mine made that squealing coming back from having a service, they didn't put a new belt on as it was in very good condition so they put it back on,so i went back to them and they put a new belt on and the squealing was no more Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
21st May 2017 9:27pm |
Not wrong there about alternators not lasting the distance now, My dad had to replace one that only lasted just two years. I have had to replace 3 on a rover metro, which is a bit of a of a job to do!
It looks like its had a replacement one though some point last year. What are the AUX belts like to do on these? the timing belt side i am scared of doing that! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
21st May 2017 9:41pm |
One of my alternators only lasted 2 months Sorry cant help you with that, my mechanic deals with all of that Clayton.
21st May 2017 9:52pm |
Well she is in for the MOT today, i am thinking it will fail. due to the fact i think it had a Bum mot on it. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
24th May 2017 12:53pm |
Any news yet? how'd she do? 1993 200Tdi Defender 90
24th May 2017 7:34pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Hope it went okay 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
24th May 2017 7:54pm |
