![]() | Home > In Car Electronics > Unused lcd screen 2008 defender? |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
Hello
People have fitted the ultra gauge in this gap, tricky but can be done. I just use it here ![]() ![]() Click image to enlarge works very well but the built in method look factory ![]() |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Sorry if this is OT but what is the steering wheel you have Stacey007? - I'm not familiar with Pumas, is this standard and if so how many splines on the column?? I'm looking to replace the worn one on my DCPU and like the look of this one.
smudger100 Member Since: 25 Jun 2013 Location: Gloucestershire Posts: 19 ![]() ![]() ![]() |
Ok - Thanks for info 007. Where does the Ultra plug into?
Ditto VVS210 on the steering wheel - nice!
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Looks like a startech wheel
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Thanks - it looks great but not £450 great...
![]() Think I'll stick to the standard factory leather version then I won't be so worried about getting mud and claret on it... |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
The ultraguage unit plugs into the port where the dealers plug into to read fault codes, cable is easily fed behind the dash to the plugs location. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
In a nut shell no you cant. The picture shows a Freelander 2 (high line) or Discovery 3 dash, which LR obviously recycled in a cut down form for the 2007 on Defender. The Freelander 2 and Discovery cluster will fit in the Defender dash but it wont work. As others have pointed out, there are after market displays than can be stuck in the same location. |
Hello
Yes its a Startech wheel around £450 new but I was lucky and found a member selling one half price ![]() I heard a Metro wheel is very similar in size. ![]() The gauge plugs into the OBDII port just under your right knee. It can be used to reset codes, fault find, or as I use it for MPH, Rev, Temperature etc. As mentioned cable hidden from view ![]() Thanks |
