Home > Puma (Tdci) > Viscous fan removal
110dc
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Viscous fan removal
How do I lock the pulley to remove my viscous fan? I have a spanner to fit but the pulley turns when I try to undo nut.
Post #623889 13th May 2017 7:25pm
ickle
There's a thread on here somewhere about the special locking spanner required.
Some have done it with a sharp tap on the spanner with a hammer
I failed with the above but a sds drill on hammer action only and chisel loosened it with barely a mark on the nut
good luck
Post #623893 13th May 2017 7:57pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Yeah it's a special tool, td5:
 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #623934 13th May 2017 9:55pm
zsd-puma
The TD5 one doesn't fit the Puma engine, but yes it's well worth having the proper tool if you intend to keep the car. There are ways around it, but they almost always end up marring the components.
For the Puma you need ref: 303-1334 from here - http://www.dingocroft.co.uk/acatalog/Tools2002-p4.html
Sadly there are few universal fitting tools for locking viscous fans, every engine manufacturer is different, so those universal ones that are available only fit a few different cars.
Post #623966 14th May 2017 5:47am
Kit
I was just giving it as an example as I couldn't find a pic of the tdci one 1993 200 Tdi 90 CSW
Post #624036 14th May 2017 1:03pm
hornet
Re: Viscous fan removal
There is no need for the specisl tool. Just use a hammer to hit the spanner counterclockwise with a strong but short stroke. Maybe you need to repeat ist, but it normally works that way.
Post #624839 17th May 2017 1:36pm
RobM
Australia 2010 Defender 110 Puma 2.4 SW Chawton White
Guys...
What size spanner is required for the Fan itself? Don't suppose its the same size as my old Tdi300?
rob Cheers.....
Rob
1995 Defender Tdi 110Wgn
2010 Defender PUMA 110Wgn
TRIPS: Meanderingdownunder WikiLoc Trips
Post #774347 22nd May 2019 9:43am
MartinK
see here
https://bellautoservices.co.uk/store/defen...y-spanner/
you also need 36mm spanner Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #774352 22nd May 2019 10:15am
RobM
Thanks for that but I had already seen that. I more interested in the actual spanner size to remove the van. I ended up finding some info off the Aulro site along with some photos and a pdf doc to make your own...
cheers..
oh... just read more from the link.... should have read further down and not just looked at the photos Sad Cheers.....
Rob
Post #774353 22nd May 2019 10:22am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Don't forget to order new knuckles!!!! Best wear gloves.... Cheers Don.
Post #774417 22nd May 2019 4:05pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Is the nut really counterclockwise to undo, as the viscous fan nut on my D3 is a left hand thread, so have been clockwise to undo? I've been hammering away on a counterclockwise and nothing has moved?
Post #777656 16th Jun 2019 2:04am
jst
Td5 spanner locking kit does fit if you just add two short bolts to two of the holes in the locking part.td5 picks up on bolts heads on pulley, tdci has holes in pulley which added studs can go into.
Alternative is spanner near vertical and sharp tap down with lump hammer with emphasis to the side that is undo. Different engine different thread. So hitting top end on of spanner rather than side. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #777665 16th Jun 2019 8:14am
One of these works pretty well to hold the pulley.
Post #777680 16th Jun 2019 10:18am
