![]() | Home > In Car Electronics > Td5 tweeters |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
the tweeters should run back to the crossover.
![]() all the dash will unscrew, including the top so plenty of room for wires. I mounted my crossovers behind instrument Binicle and by the wiper motor. Hope this gives you some ideas ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
chrispaylin93 Member Since: 13 May 2017 Location: Gloucestershire Posts: 14 ![]() ![]() ![]() |
Thanks for the speedy reply, your install looks good! From what I can see the cross over on this one is sealed into the wires coming off the component speaker? Which is really confusing me, I have attached a picture of what is labelled as the crossover!
so theres 4 wire for the tweeter and just 2 for the main ??
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
My Alpines are like that
The wire just run straight down to the component speakers mounted under the dash / footwell |
The top picture is what is listed as the crossover and as far as I can see, is fitted between the new component speaker and the original speaker wiring in my truck! Says nothing about where the tweeters should be wired in?
Maybe because the set is for a puma which already has tweeters? 🤔 |
