Home > In Car Electronics > Td5 tweeters
chrispaylin93
United Kingdom 2005 Defender 110 Td5 XS DCPU Santorini Black
Td5 tweeters
Wondered if anyone could help with this....... trying to fit a set of focal tweeters into the dash of my td5 110, would like to mount them on top of the dash but not sure where to run the wires?
Also on the tweeters I have a wire labelled "car" and an earth! There are crossovers on the component speakers but still no idea where the tweeter should be wired in!
Any help be much appreciated
Post #623826 13th May 2017 10:53am
barbel jim
the tweeters should run back to the crossover. Thumbs Up
all the dash will unscrew, including the top so plenty of room for wires. I mounted my crossovers behind instrument Binicle and by the wiper motor. Hope this gives you some ideas
Post #623828 13th May 2017 11:05am
chrispaylin93
Thanks for the speedy reply, your install looks good! From what I can see the cross over on this one is sealed into the wires coming off the component speaker? Which is really confusing me, I have attached a picture of what is labelled as the crossover!
Post #623830 13th May 2017 11:33am
chrispaylin93
Post #623831 13th May 2017 11:36am
barbel jim
so theres 4 wire for the tweeter and just 2 for the main ??
Post #623832 13th May 2017 11:53am
Tiger
My Alpines are like that
The wire just run straight down to the component speakers mounted under the dash / footwell
Post #623856 13th May 2017 3:10pm
chrispaylin93
The top picture is what is listed as the crossover and as far as I can see, is fitted between the new component speaker and the original speaker wiring in my truck! Says nothing about where the tweeters should be wired in?
Maybe because the set is for a puma which already has tweeters? 🤔
Post #623886 13th May 2017 6:08pm
