Home > Technical > LED Headlights - main beam pathetic :-( |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
This is a perfect example of you get what you pay for.
I have the JW Speakers, i fitted them myself and level adjusted them on a wall to what i though was correct. The main beam i also didn't think was great & i kept getting flashed at night. Took it to a local mot garage. The guy doing the job said they we were way out, the job cost me a couple of pints in the village pub Complete transformation on main beam, no need for extra lighting. And as for halo rings that also flash with indicators, not only look ridiculous but as Brendan mentioned, also illegal. |
11th May 2017 6:14pm |
GOR Member Since: 30 Jan 2017 Location: South Yorkshire Posts: 3 |
Hi Loz, It sounds like the yellow wire hasn’t been connected to the Side Light live. When the side lights are turned on the yellow wire sends power down to the Day Light Running Module, which will then turn the Halo ring out. The easy way to check this is to put 12v power to the yellow wire, this should turn off the halo ring. Obviously if it doesn't, get in touch with us and we'll sort asap. |
12th May 2017 10:27am |
