Home > Td5 > Turbo intermittently working - need help! |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
It could be the turbo or the MAP sensor, or something completely different. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
9th May 2017 8:13pm |
Are you sure it's the turbo? Or just a lack of pull. Try unplugging the maf and driving about for a day or two. Ray
9th May 2017 8:20pm |
Fender Member Since: 05 Sep 2009 Location: Cotswolds Posts: 3 |
Thanks for the response. My stupid but what is the MAF sensor? How do i reset it?
Cheers! |
9th May 2017 8:56pm |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
MAF == Mass Air Flow meter. The thing with wires in near the airbox. It's a couple of wires that when heated can calculate the flow of air. The problem is it can get mucky. if you disconnect the plug it will run on default settings which may make it better.
I personally suspect the turbo, leaking air pipe, or intercooler has broken. I had a turbo that was wobbling so much that the blade would stick to the housing so wouldn't spin up. You can get to the turbo easy to check it...just take the pipe off and wiggle the end. Intercooler maybe faulty and letting air out until it self-seals with pressure. But start looking for cheap and obvious first. Also, do a search for cleaning the map sensor on the inlet manifold. |
9th May 2017 9:14pm |
Thanks for the tips! I've got some time this weekend so will give these a go and let you all know!
11th May 2017 6:23am |
