Home > Maintenance & Modifications > Removing wheel nuts..
spudfan
Ireland
Yesterday having cracked the wheels nuts on the LR88 with an extension bar and a 27mm socket (they hadn't been off for a long time and were very tight) I used a half inch ratchet and a 27mm socket to remove the nuts. I found this worked better than using a wheel brace. Thought I'd pass it on. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #623146 10th May 2017 1:25pm
JOW240725
Thanks, that would seem a sensible solution Thumbs Up James
Instagram @suffolk_rovers
Post #623180 10th May 2017 4:33pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
Glad I'm not the only one! On Sunday I used a draper extending​ wrench and a 3foot length of scaffold tube to give me a decent lever
Post #623210 10th May 2017 7:29pm
roel
I use this:
http://www.toolnation.nl/milwaukee-ipwe400...eutel&
Best Land Rover investment I ever did. Roel
2003 90 Td5 (2009-now)
Post #623226 10th May 2017 8:03pm
Before I fitted my Blindos I used to carry one of these -
http://www.tyre-equipment.co.uk/acatalog/C...4WL_P.html
Cheap(ish), will easily undo the most absurdly tight nuts, and can be spun to remove them quickly. It won't fit the Blindos since the nuts are recessed too deeply in counterbores which are smaller than the tool.
Post #623267 10th May 2017 9:24pm
miker
Keep a breaker bar in the boot at all times, in all my vehicles! Only about £25 for a sealey 1/2" one that works fine.
Also usually have my 18v impact driver on me!
Post #623270 10th May 2017 9:28pm
Carrying a leverage bar for wheel changing purposes will be a weapon next. Rolling Eyes
I carry about a 3ft square tube steel bar too. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #623278 10th May 2017 9:48pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
24" nuckle bar and a socket for me, bought it for my first series motor and have used it in all my Landys since. If you need a 3' extension bar to crack your wheel nuts then they are on a tad tight Shocked
Post #623286 10th May 2017 10:06pm
I don't really need it that long, just easier. Laughing
I'm sure some clowns have overtightened mine before, normally MOT men not servicing.
Some seeto think a Defender is a HGV I think when it comes to wheel nut torques etc.
I've known the handbrake being put on far to tight before too.
But yes, a bar just makes a heavier job that bit lighter. Play Stupid Games, Win Stupid Prizes.
Post #623291 10th May 2017 10:24pm
spudfan
Ireland
My main point was that the ratchet and socket was a lot easier to use than the wheelbrace, especially on the lower nuts where the brace would hit off the ground. 1982 88" 2.25 diesel
Post #623301 10th May 2017 11:15pm
pannawonica
Australia
I always use a torque wrench ( warren and brown ) too tighten wheel nuts. However too release greater torque is required. As a result I have been using nickel anti seize with no ill effect for a long time. Thumbs Up I have never researched this, however works for me Thumbs Up
Post #623303 11th May 2017 12:04am
agentmulder
Kuwait
Summed up thusly:
> Ratchets are great, but breaker bars are sometimes required to get things started
> torque = torque
(??) Solved the bowel problem, working on the consonants...
Post #623304 11th May 2017 12:23am
Mo Murphy
I only use the land rover wheel wrench on my wheel nuts to tighten and loosen. Its length means that you cant overtighten the wheel nuts by hand and so do not need breaker bar or scaffold pole to undo them.
Over the last 20 odd years I've neither had a nut come loose nor been unable to undo a wheel nut at the roadside.
I rather suspect the wheel wrench is that length for a reason 😉
50 Shades of Pennine Grey
Post #623330 11th May 2017 7:16am
spudfan
Ireland
I agree with the point about the Land Rover wheel brace which is what I use to tighten the nuts. Mine had been put on in a tyre fitting place two years ago and were torqued correctly...I had it written down! They just seem to tighten over time, I'm getting older!!
The ratchet enabled me to loosen the nuts without taking on and off the wheel brace. Sometimes when turning the brace it'll hit off the ground depending where the nut is. 1982 88" 2.25 diesel
Post #623354 11th May 2017 9:45am
zsd-puma
The danger with a ratchet is the prawl inside can fail when trying to brake something free, sure you can buy a snap on one with it's life time warranty, but that just means they'll replace it when it breaks.
A breaker bar is better as there is no prawl to snap, and because they are hinged, so when you encounter the issue with it hitting the ground you just flip it out a bit to clear it.
Post #623366 11th May 2017 10:58am
