Home > Maintenance & Modifications > electrical woes
countdecash
Ireland 1999 Defender 90 Td5 CSW Epsom Green
electrical woes
Morning guys......few weeks ago i noticed my reversing lights weren't working .....presumed it was the switch but it turned out to be a fuse. The following day landy wouldn't start.Battery was flat so after charging battery i put a new alternator on it. Last night i noticed the reversing lights were gone again. I changed the fuse and hey presto they worked. However out this morning and the landy wouldn't start. Battery flat and when i checked the fuse was blown again for reversing lights. Is this coincidence or have i a short somewhere?
Post #622817 9th May 2017 8:04am
countdecash
its a 99 td5 90
Post #622818 9th May 2017 8:05am
dorsetsmith
brake and reversing lamps have switch feed and fused and feed from ignition switch Exclamation so not work with the ignition key out
you need check for short cct in brake and reversing lamp cct see wiring digram as the same fuse is used both
As to your Battery flatting problem
Post #622823 9th May 2017 8:46am
countdecash
Thanks for the reply and diagram. They dont come on with key out or ignition off but i presume there's a short somewhere. I'll get it checked out
Post #622830 9th May 2017 9:39am
PaulMc
As well as the brake and reversing lights, the same circuit supplies the alternator and speed sensor.
Green/Yellow wire circuit goes from Fuse 6 in the facia fuse box, to header C0292 -
From C0292, it goes to header C0294 -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #622871 9th May 2017 12:20pm
dorsetsmith
beat me too it Thumbs Up just back from call out
Post #622875 9th May 2017 12:36pm
