Home > Maintenance & Modifications > electrical woes |
countdecash Member Since: 14 Mar 2016 Location: dublin Posts: 24 |
its a 99 td5 90
9th May 2017 8:05am |
Click image to enlarge brake and reversing lamps have switch feed and fused and feed from ignition switch so not work with the ignition key out you need check for short cct in brake and reversing lamp cct see wiring digram as the same fuse is used both As to your Battery flatting problem |
9th May 2017 8:46am |
Thanks for the reply and diagram. They dont come on with key out or ignition off but i presume there's a short somewhere. I'll get it checked out
9th May 2017 9:39am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 502 |
As well as the brake and reversing lights, the same circuit supplies the alternator and speed sensor.
Green/Yellow wire circuit goes from Fuse 6 in the facia fuse box, to header C0292 - Click image to enlarge Click image to enlarge From C0292, it goes to header C0294 - Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
9th May 2017 12:20pm |
beat me too it just back from call out
9th May 2017 12:36pm |
