Home > Puma (Tdci) > which battery to go for?
bear100
my battery is starting to play up now not bad for 7 years of service!
My question is what is the best to replace with? i will in the near future fit a twin set up so with that in mind what would be your preferred choice?
Thumbs Up Thumbs Up Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #622371 7th May 2017 11:13am
Bluest
After much research on here I bought a Varta LFD90 a few weeks ago. All I can say is that it works, was the same dimensions as the original and.... errr comes in smart silver grey colour! 2007 110 TDCi Station Wagon XS
Post #622374 7th May 2017 11:18am
Cupboard
I've gone for a Varta too, a Silver Dynamic. The size you need is a 019 and Tayna have a good selection and decent service.
https://www.tayna.co.uk/Type-019-Varta-Sil...P3127.html
You don't need an AGM battery unless you're regularly turning the vehicle upside down.
Things like Odysseys are available and you do get good cranking amps and useable capacity in a package that's a bit smaller, the cost is that they're very expensive. Don't bee too led by the fact that an Odyssey has lower headline capacity, they're actually rated to a lower depth of discharge than a standard flooded battery so overall usable capacity is about the same. That said, I wouldn't choose one myself because they are so expensive for negligible benefit for most applications in a Defender.
Post #622398 7th May 2017 2:15pm
ericvv
Doing a search on the Varta website for suitable batteries for a Defender Tdci turns up these two results.
https://www.varta-automotive.com/en-gb/bat...mp;ss_etn=
The Silver Dynamic is what I will go for too when the time will come to replace my original Varta which after more than 8.5 years still does not show any sign of weakness. Maybe I will replace it at 9 years young later this year before the next winter just for the piece of mind, but point is that it is holding its charge perfectly for weeks at length so I might postpone by another year.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #622415 7th May 2017 3:48pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
2007 here still on it's original Varta (I've owned it since 2008).
Will replace with same, no issues yet, although it's driven regularly with only the occasional 3 days max without moving.
Post #622458 7th May 2017 6:22pm
zsd-puma
I've got a Yuasa one from Halfords, it's the same size (and reference number) as the original, but it's 100Ah instead of 90Ah and the CCA is higher too.
Post #622474 7th May 2017 6:53pm
nickhodgson
If you were happy with the battery that lasted 7 years then why not go for the same one again. I assume it was a genuine LR one (which is a Varta and is very good quality). I understand that the exact spec matching battery that Varta supply to Land Rover is not available through Varta. If I remember correctly the LR batteries is a combined leisure battery.
There was a post some time ago that explained it all.
If you are doing dual batteries in the future then you could use two of the LR Genuine ones. They do fit into the battery box with some fiddling and revision of the clamps/terminals and some patience. I have this arrangement in one of my Pumas along with a dual battery solenoid. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #622589 8th May 2017 7:10am
ibexman
Show us some pics Thumbs Up
Post #622592 8th May 2017 7:52am
zsd-puma
Because they're over £200. Don't get me wrong the Genuine Land Rover batteries are good, but i don't think they're £200 good. There might be an advantage to them if you're doing a lot of winching, but for normal use there are plenty of much cheaper and equally good quality ones available.
7 years seems to be about the average life of most car batteries i've had. Some have lasted a bit longer, but i've usually noticed a difference once a new one was fitted, which suggests the old one was getting tired long before it finally died.
Post #622694 8th May 2017 4:11pm
gilarion
No matter which battery you have invest in a CTEK charger with a battery reconditioning mode and every two years or sooner use that mode and you will get the maximum life out of your battery.
I have even rescued dead batteries with the CTEK battery reconditioning mode.
http://speed.academy/how-to-maintain-car-batteries-ctek/ For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #622703 8th May 2017 4:58pm
zsd-puma
I've got one of these, great bit of kit.
http://www.halfords.com/workshop-tools/gar...d-diagnose
Post #622707 8th May 2017 5:16pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Nick,
I would like to do a dual standard battery install and would be interested in seeing photos of your arrangements if that's possible please?
Post #622787 8th May 2017 9:31pm
nickhodgson
I believe this is the latest part number for Defender Puma battery. Superseded from YGD500160. That price for the Genuine one is plus VAT.
Interestingly for the Britpart fans it seems that their OEM battery for a Defender Puma is a Lucas. I am unaware that Lucas have ever been fitted to a Puma so would then worry about the quality of other Britpart OEM products.....
I am not with the vehicle at the moment as it is parked up elsewhere but two of the YGD500160 batteries fitted into the battery box. Not a simple job but possible with effort - but no cutting of forcing of components. 1995 300tdi Defender 90 P/UP
Post #622804 9th May 2017 6:49am
bear100
Thanks guys, lots of info Thumbs Up TBH I thought odessey and Optima would have had more mentions?
Gilarion, good read the CTEK blog! I might get one, the defender doesn't get much use nowadays about 30 mins every Sunday for shooting. 2016 Range Rover Autobiography 4.4 TDV8
Post #622825 9th May 2017 9:11am
Dieselhead
I am on the same battery atm new in 2008
Changed out a battery in a works td5 few months ago which was new in 2004.
Not bad I dont think Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #625241 18th May 2017 8:48pm
