Home > Technical > Handbrake cure |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
quick then mate,nice one. 2.4 90 XS
12th Jan 2009 12:44pm |
should have said quick fix,oops 2.4 90 XS
12th Jan 2009 3:57pm |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
Austen
Thanks for the update, I took mine to the dealer and they replaced the drum, and reset the cable to near factory spec, although it was 4 clicks to engage, but the problem came back. I have tried your solution and all seems good. My only concern is that I am now out of thread / adjustment on the cable end and have had to back the actuator on the drum an extra quarter turn to get rid of the judder. It is only on long runs, 400 miles, that the heat seems to build up enough, I wonder if the outer is expanding at a different rate to the inner cable and dragging it on. |
17th Jan 2009 7:10pm |
austen Member Since: 10 Mar 2008 Location: Sydney Posts: 52 |
Sticky
I have about 15mm of thread still visible on the cable adjuster. Sounds wrong that you are out of thread. Austen. Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
18th Jan 2009 10:11pm |
I will get the dealer to look at it.
Perhaps it is an out of spec part. Thanks again |
18th Jan 2009 10:23pm |
