![]() | Home > Maintenance & Modifications > Looking at new engine options for Defender |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Or the Defender Puma transmission, as it's basically the same box used in the Mustang. |
Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72 ![]() ![]() |
Ford Ecoboost 3.5lt V6.... 365 bhp and 420 lbs.ft and a lot shorter than a V8.. more space less head scratching
![]() ML 270CDI |
What have you got Mighit?
^ if that's aimed at me.. I'd have thought that my avitar and signature would have given it away
![]() But I'm looking to drop an OM605 in to the old bus at some point... although I'm waiting to see what happens with the latest Diesel Witch hunt throws up... All I want is bags of torque and below 2000 rpm... that's rather Diesel territory not Petrol... But who knows... I could go big V8... just not bloody ECU's.... ![]() ![]() ML 270CDI |
I once had an Overfinch RRC with the 5.7 in it, it went rather well.
Why not go for the 606? There's a member on here who has put one in his 110 ![]() It's the one in this video. |
Simple.. if you actually go on the diesel pump uk site and look at the converted pumps for the OM606 and OM605 they have the same output levels... I do realise that there will be a slight loss in power due to 1 cylinder less, but it's a small price for a lump that's way shorter and easier to squeeze in... After all, I believe that the OM606 conversion is suffering from a few clearance clarence problems cos the transmission is a wee bit too long, and I believe that the Defender has a flat bulkhead, which is more than can be said for the RRC, which has some of the engine tucked under the back of the engine bay..
Or put it another way, my car has a 2" body lift and it's tight to get the rear rocker cover off, I wouldn't want to try it on a standard car ![]() And the RRC conversion is rumored to have problems with the oil filter, which then needs to be remote mounted with a lot of head scratching, if I can get almost the same power, with a few less torques but an easier install..... RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
Really? Surprising! I wouldnt have thought the Puma tranny could take the power. Good to know though, maybe a few uprated bits would be needed and saves having to get an adaptor for the tx box |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
This is a cracking thread and i'm having an awesome time reading it
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 ![]() ![]() ![]() |
Sensible advice from me below!
I believe you have a Puma? If so just remap it and if that's still not enough fit a larger intercooler and bigger turbo. It will save you probably somewhere between 15 and 50k depending on which ever engine you decide to fit. Fitting an old 350 chev or any similar era engine is going to be a nightmare. You will have canbus to the instrument pack you will have to deal with. That is involved enough where you can link the engine canbus to the dash canbus which you can do with the LS engines. It will be far harder with an older engine. You cant swap out instruments easily in a Puma dash either. 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
BAS used to do a puma 3.2 conversion, potentially more or less big block torque and it looked like a factory installation. Not cheap, however when was anything very good and cheap!
