Home > Maintenance & Modifications > Looking at new engine options for Defender
V8Smith
Hi guys, we finally have our Defender and its so much fun. Just thinking at some point we might give it a bit more power and possibly go auto too. So looking at what engine to go for for the best combination of performance/economy/feel of the car etc, so options I have thought of are:
1. A Range Rover / TVR 4ltr or 4.6ltr V8 with an auto box, Im thinking this might be the most authentic and the easiest/cheapest to do, although I have nothing to base this on other than a feeling
2. A Discovery 4 3ltr TDV6 engine, would be plenty quick enough and its a quietish, smooth engine, so might be a good option, as it will be more economical than a V8
3. A LS3 V8, which is a great engine, but Im thinking this would prove the most expensive, but by far the most reliable and the most power, but not sure I need this much power.
SO does anyone have any experience with the options above, or other options we should consider, all help and advice would be really appreciated. I think I would like a muffled V8 burble though if I'm honest, my gut tells me the Rover V8. Obvious additions are which gearbox we should use with the options above too.
Thanks guys, I'm really looking forward to transforming our Landy into the perfect car for us..
Mike
Post #621138 2nd May 2017 7:54pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
tdv6 is a lovely smooth powerful engine, But its like a Pheasant always looking for a new way to die.
Post #621174 2nd May 2017 9:32pm
There was somebody here recently extolling the virtues of 6 cylinder Jag engines. Loads of power, robust and apparently cheap as chips as nobody ever needs to replace them. As a more modern engine, they're also more economical too. Darren
Post #621176 2nd May 2017 9:35pm
davew
V8 petrol every time unless you want the fuel range of a diesel. This is particularly the case given the current hate towards diesel by those who think they have a clue about running a country. There's an irony that my TD5 90 is excluded from London but I'm welcome to take my 5.7 LS1/6 V8 in.
As you say, cheapest option and simplest too is to slot an RV8 and matching box in it. It won't give you the power of an LS without serious money but if you're not looking for huge amounts of power it's cheap and easy to keep running. You can buy a V8 Auto P38 with a Thor engine for next to nothing and if you're canny you can sell on enough bits to break even on the deal and get the bits you need for free. Convert it to Megasquirt to get rid of most of the wiring and get a controller kit and transfer box adaptor from Ashcroft. Alternatively you can play with the electrics on the P38 but it's not easy to separate them out. You can always match it up to a hydraulic 4 speed ZF though and it will slot in to a Defender with very little modification.
Another cheap option and something a bit less usual would be to use a Lexus V8, lots of power and the electronics are pretty much self contained. Depending on your choice of gearbox you may need to get an adapter manufactured though.
LS engines are very nice to have but parts are hard to come by (although it's slowly getting easier) in the UK so when something goes wrong it can take time and money to get the parts you need. As an example the idler and tensioner pulleys on mine, especially the idler pulley, are prone to failure in an off road environment due to grit getting into the bearings. If I were to buy one from the US the pulley itself would be about £15, the postage though is nearer £70. As a result I went out and had to find someone to machine the pulley to take a sealed bearing instead. Not as easy or anywhere near as quick or cheap as getting a similar item for a serpentine RV8. http://www.yorkshireoffroadclub.net/
Post #621186 2nd May 2017 10:27pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
1. - Will be the easiest and cheapest
2 and 3 will both be expensive. 3 will be a lot simpler than 2 in a number of ways. for instance the cooling system on an LS is very simple. No modern LR engine appears to have a simple cooling system!
You can also buy adaptors to fit the lt230 onto the 6l80e (the 6spd auto commonly found behind recent LS engines)
I have just done #3 and am fairly aware of the trials, tribulations and costs involved!
The majority of parts will be harder to come by for an LS conversion in the UK than here, and especially in the states. 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #621187 2nd May 2017 10:30pm
Pickles
LS3 is the way to go, but to be fair, it's horrendously expensive, and of course it's not just the engine, there's the driveline, brakes, transmission etc, a VERY complex job, but ok I suppose if ya've got the dollars & ya really want POWER (Grunt)!!
Apart from that, you could do a good job modifying an early LR V8,..3.5, 3.9,...don't know much about 'em,...will the 3.9 go to 4.2?,..but I guess with the right innards, pistons, heads, camshaft, exhaust etc, you would get quite a lift with a relatively simple instal?
Pickles.
Post #621191 2nd May 2017 11:27pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
why dont you put the same engine in, being td5 or td4?
do you feel the need for improvement?
I drive a puma 2.2 and I find the power plenty enough (I have bas remap....
for me I think, the defender is just unsafe going fast
Post #621199 3rd May 2017 3:23am
I went for option 1. GEMS 4.6, which everybody will tell you do megasquirt, but try not to. The hose routing in my picture is now different. She pulls like crazy and I've I'm still running it in. 260 miles so far.
An LS is fine, a mate now throws these in ultra 4 trucks on a monthly basis....it's getting easier as Dave said.
Post #621204 3rd May 2017 5:41am
V8GPC
I'm lucky enough to have one of the defender 50th's which have the factory fitted 4.0 GEMS and Auto gearbox;
Its definately the nicest Defender to drive.
There are plenty of range rovers going cheap as a donnor; but is going to be loads of work.
There are a few Japan Imported 50ths for sale (RHD) at the moment on eBay... about £25k mark which seems the going rate at the moment. (it would be more expesnive to import one now - based on the £).
The 50ths come with aircon and roll cage as standard; and definately one go down in value.
Maybe you want to sell / trade in what you have and go for a factory option.
Post #621207 3rd May 2017 6:05am
Miggit
Why all the LS3? Wot's wrong with the Chevy 350Ci? way cheaper, about a third of the price... it was good enough for the Overfinch Classic's.... RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #621240 3rd May 2017 8:38am
Miggit
Whistle If you're going to drop in a Yank, this place will give you an idea of what is available off the shelf in the UK... http://www.realsteel.co.uk/
FYI if you fit a old engine to a new car then the MOT emissions have to meet the requirement for the year of ENGINE manufacture, not the car... and if you put a new engine in an old car it has to meet the standards for the the year the car was made Shocked So that's win win, and the older date trumps everything... So if you were to get a 70's engine then emissions are about 6% from memory and if you can get a 60's then anything goes... as long as it's not burning too much oil!!
If your looking for 250 - 300 BHP then I'd be either looking at a 350CI chevy of a 351 Ford Windsor engine, and personally, run it on a carb, or two, or three Twisted Evil
This page makes for an interesting starting point and gives the emission standards, which I got slightly wrong Embarassed
http://www.realsteel.co.uk/usedengines.pdf RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #621245 3rd May 2017 8:50am
davew
1/3 the price ? If you compare second hand with new maybe. It is 70kg heavier and also about half the power and torque unless you throw a lot more money at it...
If you take 50+ years of experience with big V8 petrols, their faults and their advantages, then rather than trying to modify what you have you start with a blank sheet of paper, you get the LSx.
Having said all that though, while the 350 is a bit more agricultural in nature it is a bloody good and very strong engine. I just think if you're going to go to all the expense and challenges of putting in a GM engine and matching it up to the transmission, any additional cost of an LSx pales into insignificance. http://www.yorkshireoffroadclub.net/
Post #621256 3rd May 2017 9:44am
Miggit
Correct me if I'm wrong but don't LS engines start at around £6500 and go up depending on what spec they are? And all the LS engines are ECU controlled, so apart from all the ball ache that can cause you've also got cats to deal with... more expence as they'll need to be free flow high volume jobs...
Where as you can get get a turnkey 350 Chevy crate motor for around £2000..... that's a lot of change to sort out your transmission hiccups.... Whistle not to mention that you could be cat free and legal, with the correct engine choice.
I also notice that Realsteel are selling GM crate engines, and a 333BHP turnkey 350 SB is £4000, so that's still £2500 towards the tranny!
And if you went for 250BHP then you could start with one of the S/H engines that they sell for £300 and totally rebuild it for less, hell you could even splash out on a set of stage 3 ally heads and have change Wink RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
Post #621260 3rd May 2017 10:01am
bankz5152
What about the Ford Coyote 5L V8? Cheaper engine, plenty of power for a Defender (I think they may even be more economical than the LS) plus apparently you can use the transmission/clutch from the 2007+ Mustangs auto or manual.
Post #621273 3rd May 2017 10:47am
davew
That sounds about right for a Turnkey engine but I think you might be comparing a Turnkey LS1 to a 350 Crate engine ? I'll be honest I've not looked at prices recently as I'm not in the market for an engine but buying direct from the US I've not seen that big a discrepancy in like for like packages in the past. The UK market might be skewed though as I expect supply and demand makes for bigger profit margins. When I bought my engine the exchange rate was much better and the engine (turnkey - ECU) cost me £4,300 delivered and the gearbox another £1,400 and they were both shipped air freight !
The cost of the engine and gearbox was around half the cost of the conversion in the end by the time I'd got a custom rad and oil cooler, exhaust, transfer box adaptor and all the other "stuff" that costs small amounts each but add up when you put them all together !
Not sure what you mean regarding cats ? If you're fitting the engine to a vehicle that requires cats and you're fitting a new engine then the 350 will also need cats. There's no reason at all that you need cats just because it has an ECU, it will be based on the vehicle's age (assuming a new engine) and has nothing to do with the engine or it's ECU. Most ECUs can be configured to run with or without cats and most don't care as the cats are downstream from the sensors. http://www.yorkshireoffroadclub.net/
Post #621275 3rd May 2017 10:59am
