Home > Maintenance & Modifications > Defender 110 standard suspension.
Lrd300
Malta 2004 Defender 90 Td5 ST Barolo Black
I just bought a 2004 double cab td5 110. Currently the 110 has a 2 inch or more lift and i would like to put it back to standard height or enough to fit 255/85 16 tyres, which i guess should fit with standard suspension.
This will be used mainly for road use and unladen. What springs do you suggest fitting for a good ride ?
Thanks Wink
Post #620733 1st May 2017 12:10pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I've just removed a 2" lift from my 2002 Td5 DCPU which has 265/75R16 tyres. The front springs were standard fit with a spacer underneath (now removed) but the rear springs were yellow (Britpart?) so had to be replaced. I fitted some delivery miles take-off RBK101111 springs from eBay and I'm very happy with the result. The dampers were fine so they've been reused but it was a complete ball-ache to undo the bottom nuts from the front set. It would've been a lot quicker to cut them off and fit a new set.
If anyone wants the old front spacers and yellow springs please send me a PM.
Post #620823 1st May 2017 6:20pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Also, you could contact the various tuning companies. They tend to sell on the parts they remove at reasonable prices. I bought a full set of springs and dampers from twisted. 2002 110 td5
Post #620887 1st May 2017 8:23pm
Intercept
Indeed, my virtually new genuine LR rear springs came from https://www.trekoverland.com for £60 the pair inc delivery.
Post #620891 1st May 2017 8:45pm
