Home > Off Topic > Grease Guns... which one?
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Some advise from all you knowledgeable chaps...
I'm needing to get a new grease gun and while checking prices online, I found a 'mini' grease gun...
I only grease my prop shafts and tie-rod ends will be added when the non-grease ones wear out.
Would the mini work or is it better to go for a standard gun?
Mini: 30cc & 1000psi
Standard: 400cc & 2500+psi
Thanks in advance Thumbs Up Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #620732 1st May 2017 12:01pm
Bluest
I struggle to get grease in my prop with a full size gun, a mini one wouldn't touch them. 2007 110 TDCi Station Wagon XS
Post #620734 1st May 2017 12:11pm
zsd-puma
Wanner if you can find one on ebay. New they're crazy expensive, but used ones are pretty cheap. Swiss made and unlike the cheap ones the end actually seals onto nipples properlly yet is still easy to remove. You can operate them one handed as they're the small type you fill from a pot rather than the large cartridge ones. They're extremely high powered especially for their size.
http://www.ebay.co.uk/itm/wanner-high-pres...SwSlBY4VcT
Post #620738 1st May 2017 12:32pm
gilarion
^^^^^^ Thumbs Up
If you can get hold of a Swiss made Wanner, then that is all you need I have had a Wanner for twenty five years and it is still as good today as the day I bought it, fiddly to fill but works like a charm.
Failing that then any good trigger pump gun from Machine mart or Screwfix will be good. Personally I would go for one that fits a grease cartridge as filling the spring loaded guns from a can of grease is a chore. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #620742 1st May 2017 12:36pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I use these for greasing the plant at work. Good value at £12
Post #620771 1st May 2017 3:00pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Still using a Wanner 315 from the late 60s. Excellent bit of kit. One wife - livid
Post #620779 1st May 2017 3:42pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Thumbs Up +1 for the Wanner
Post #620791 1st May 2017 4:41pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
I have one of the mini ones, picked up at a car boot sale. Old skool and made out of brass. I use it for the Matchless mostly but it does get used on nipples where ever it is needed even on the land rover.
Post #620798 1st May 2017 4:50pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Also have a Wanner 315 high pressure Grease Gun and it must be from the 60s as it was my dad's still in perfect working order it's just a well made tool.
Post #620826 1st May 2017 6:26pm
discomog
I bought a Wanner in 1965 when I was an apprentice and it's still in use today. It's even better when fitted with a flex hose for those awkward to get at grease nipples. Thoroughly recommend Wanner Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #620842 1st May 2017 7:07pm
Cupboard
The one in the first picture looks rather like the RS one that I have in my work tool bag. The only good thing I can say about it is that it's small. I wish I had the space for a less rubbish one.
Post #620903 1st May 2017 9:24pm
Bushpig
Thanks for all the replies Thumbs Up
My main reason for going for a mini, was space in my 'rover box'.
Cupboard:
That is indeed the RS one, and is only ZAR20 more than a normal one.
Can you confirm that it does the UJ's?
Cheers Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #620947 2nd May 2017 6:03am
X4SKP
Hello Bushpig
I have 3 all essentially doing the same job, but I always use the smallest Gun
to Grease the Prop Shaft UJ's, often without moving the vehicle forward I will get
to all of them because the small Gun will be more maneuverable within the space
available...and as you say...it's a smaller bit of kit to carry too.
The two alloy Guns are Tecalemit, British Products...now described as 'Vintage Tools'
these were my fathers, used on 1950 Motor Cycles...still going strong... Thumbs Up
Good Luck... SKIP
Post #620963 2nd May 2017 9:00am
Cupboard
Bushpig wrote:
Cupboard:
But that would mean using my inferior work grease on my Defender Rolling with laughter
I'll have a go tomorrow.
Post #621375 3rd May 2017 5:09pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I use my dad's Wanner. It is probably 50 years old and works well. 2002 110 td5
Post #621417 3rd May 2017 7:16pm
