Home > Maintenance & Modifications > Brake Upgrade for Puma
Page 1 of 3 123>
AndrewS
I have searched but failed to find any info on our site.
Has anyone upgraded the brakes or the callipers on a Puma?
I know that you can fit drilled and grooved discs along with green pads for a reasonable price.
The next step up that I can find is the JE Engineering option that involves AP-callipers etc etc this costs around 3k excl vat.
If anyone can help with advice to the following two questions I would be grateful.
Are there any performance 'bolt on' calliper options available?
Would braded hoses improve or make that much difference to the brakes?
What are your views? 130's have feeling's as well you know Smile
Post #62065 3rd Mar 2011 7:48pm
Surrey Rover
Having spent an unhealthy amount of time riding around in odd shaped circles my thoughts on braided hoses are that whilst they will make a small improvement the real point of them is to avoid brake fade. I would be surprised under normal use be it on or off road if you managed to get brake fade in a Defender therefore probably are not worth doing.
Like anything it can't hurt but the investment in your time probably won't repay itself, whilst I have fond memories of AP brakes and master cylinders 3K for hauling up a slow moving Tonka toy is a bit extreme, I would love to have them though Cool
Post #62067 3rd Mar 2011 8:01pm
Martin
Site Admin
Alive Tuning do brake upgrades I think - worth a call?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #62069 3rd Mar 2011 8:11pm
Lorryman100
If I could justify the £2000.00, I would ask Alive for a forum discount and go down this road or if I was feeling really flush then it would be the Entreq solution once it is developed. (I've had Brembo callipers on road cars and they are the dogs danglies IMHO.)
So if I was to get any of the above done I would go the whole hog with SS braided hoses and would not go for drilled or grooved brake discs as that would give mud/grit/stones somewhere to live and would help to destroy 2grands worth of brakes. The extra stopping power when towing would be the main advantage as an unbraked 750kg trailer still exerts a fair bit of force when trying to stop in a hurry. Also the 2 ton caravan with overrun brakes doesn't help the Landy stop that quick either Whistle
Post #62071 3rd Mar 2011 8:22pm
Ian (Porny) @ IRB also does brake kits.
Don't hold your breath waiting for a reply though. Rolling Eyes
Post #62074 3rd Mar 2011 8:24pm
MK
Remove to the urban myth section Puma 110" SW
Post #62086 3rd Mar 2011 9:01pm
nakatanenga
Germany
I am driving Land Rovers for 17 years now and the only bad brakes i had were in a 109 V8 with RRC engine where speed was limitited only by courage and skill of the driver.
If a DEFENDER brake system is in good condition, the calipers are moving fine and the discs are thick enough there is enough stopping power, even for heavy laden cars.
Useful upgrades: cross drilled discs, braided hoses, Ultimax pads etc give better performance. Also the use of an ABS type brake booster are all little by little helpful but are not rocket engeneering.
An additional electric brake pump gives impressive stopping power....
The dimensions of the OE stuff is OK. If it is maintained well it will stop the train.... WANTED:
SII or SIII in max 1.5k
Post #62088 3rd Mar 2011 9:04pm
AndrewS
I agree with the comments above stating that the standard brakes are/should be good enough, however I have found that the 130 we have (J-Lo) weighing in at approx 2.6t ish takes some stopping compared to a standard Defender 130. Clearly we drive accordingly and keep the speed down.
My goal is to improve the brakes a little to give it the same stopping power/distance (whatever its called) as a standard 130.
I know that there are other factors involved here, tyre type, road conditions. There is no point fitting huge rotors/disc's if there is no grip available from the off road bias tyres fitted to the vehicle. 130's have feeling's as well you know Smile
Post #62105 3rd Mar 2011 9:30pm
noworries4x4
Brakes
I run the option you said in the first post EBC drilled slotted discs and green stuff pads makes a big difference and also if you are towing keep the brakes very well adjusted so the over run cuts in early and does not push to much.
You do have to be a little careful when they are stone cold in the morning once warmed up superb If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #62108 3rd Mar 2011 9:38pm
jst
braided hoses won't add any difference that you would notice under normal conditions as you describe in my experience.
is it brake assistance you are running out of or just stopping bite? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #62117 3rd Mar 2011 9:55pm
landy andy
I found adding braided hoses made for a much nicer pedal
Andy
Post #62121 3rd Mar 2011 10:11pm
jst
my pedal still looked the same after i fitted mine. Shocked Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #62123 3rd Mar 2011 10:30pm
noworries4x4
I have just read the above again and yes i do know i had to get mine re-plated with HD springs and anti roll bars but my 90 kerbs at 2.9t full tank and me its now plated to 2950 mam (max auth mass) and 6450 max train and the green stuff stops that fine even on 265 bfg all terrains If everything is under control you are not going fast enough.
No Worries 4X4
Post #62138 3rd Mar 2011 11:28pm
Alive Tuning
Although I offer a 6 pot billet conversion for Defender Front brakes, I will shortly be adding a 4 pot billet front calliper conversion too, which can be made to work with either standard size discs, or 2 part bell/rotor as used with our monster 6 conversion.
The beauty of billet brake callipers, is that they can be made to virtually any size, without much difficulty. They're also of a more rigid construction than cast callipers, so give better response. Exclamation
Have spent a lot of time testing EBC discs/pads on Defender and Discovery II, and they are not as effective as genuine LR discs/pads. I find that those who say they made a big difference, also say their previous discs/pads were shot when they fitted them! Rolling Eyes
Post #62347 4th Mar 2011 11:23pm
landy andy
I am runnung EBC pads and don't rate them.
They have a very small window of operation. They don't like the cold, and overheat easily.
Won't bother again.
My next mod will be to change calipers to 110 ones and vented discs.
Andy
Post #62356 5th Mar 2011 9:40am
Page 1 of 3 123>
