Home > Technical > Glowplug light
Jonathan111
Glowplug light
Hi all, wonder if you advise. Just had an engine rebuild done which was not a happy experience and on taking the vehicle back , see that glowplug light on dash doesn't switch off. Everything else, engine worked fine and got me home (one mile). Is there any significance to this? The garage said that I should have my fuel injectors overhauled and put in a second hand one. Any thoughts gratefully received, cheers, J
Post #619890 27th Apr 2017 10:55am
zsd-puma
I'm not sure what model you have but the glowplugs will be controlled by a timer relay and a temperature sensor on the head. Maybe there is a short somewhere? Look for pinched cables or anything that's not plugged in.
Post #619892 27th Apr 2017 11:00am
Jonathan111
Hi there, thanks for this : its a 300tdi 1998. Cheers, J
Post #619893 27th Apr 2017 11:03am
dorsetsmith
Post #619899 27th Apr 2017 12:16pm
Jonathan111
Hi, thanks for this, any chance you have the ignition circuit diagramme for the 300tdi? Will Google around for it if no go, Thanks in advance, Jonathan
Post #619901 27th Apr 2017 12:18pm
dorsetsmith
Post #619904 27th Apr 2017 12:27pm
