Home > Maintenance & Modifications > Clutch pedal spring mod
Page 2 of 2 <12
bankz5152
It looks to be fitted the exact same way as mine! Very odd.
Post #619882 27th Apr 2017 10:04am
Drew.s
United Kingdom 2004 Defender 90 Td5 SW Epsom Green
Have ordered a spring kit.
Will report once it's fitted.
Drew
Post #742018 24th Nov 2018 3:54pm
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
If you assembled it correctly. With the clutch master cylinder screw disconnected ie nut taken off and the pedal free you will find the spring will pull the pedal to the floor. It should do this as this is how it assists the clutch action. If it does not do this the spring is fitted incorrectly. Hope this helps.
Post #742145 25th Nov 2018 2:09pm
Page 2 of 2 <12
