![]() | Home > Technical > Nanocom help |
I'm having a total brain dead day and can't see where I'm going wrong. I've just had new injectors fitted to my td5 and want to code them in with the nanocom evo but I think I'm doing it wrong. I went to the injector code page and thought you just deleted the codes and put the new ones in but when I go back into the injector page it's put the old codes back
![]() ![]() Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
The plot thickens........ I've just been back on and now it changed the codes to what I put in except on injector 1 and injector 5 it's got the wrong last letter
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
On the next page it says write setting which I pressed, it then came up write to ecu so I pressed yes then it goes back to the first screen. I don't understand why it decided to change them after about half an hour but made two letters wrong
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Have you tried doing it with a Laptop Ray?
My Nanocom (version 1) is much easier if used with a Laptop rather than just the unit. I've got the software if you need it? |
Hi, thanks for the offer but computers are like witchcraft to me
