Home > Td5 > Battery light on dash
adeparko
Scotland 2007 Defender 90 Td5 HT Sumatra Black
My wife has just phoned to say the battery light is staying lit on the dash
Just wondering what to check? Assume battery light usually points to alternator?
Only problem is cant get access to the battery quickly with the seats being aftermarket. If I put my meter on the output stud of the alternator I take I should be seeing 14V+ there?
Thanks
Post #619461 25th Apr 2017 5:08pm
miker
Correct on 14V or so, mine tends to sit a bit lower than that when warm. Careful of moving parts, and make sure you are testing to a decent ground point, I find you need to scratch around on the block at times to get one!!
Mike
Post #619462 25th Apr 2017 5:17pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
As said above, correct and good advice... Its probably your rectifier or it needs servicing. You can get kits on ebay to repair it. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #619560 26th Apr 2017 12:59am
roel
You don't need to measure near the engine. You can take the fuse cover off and measure there if that is easier. My 90 td5 produces 14,1 V normally without any electrics switched on. It is not a steady signal most voltmeters don't react that quickly so you see a steady 14V but in fact it fluctuates between 13 and 14V. Roel
2003 90 Td5 (2009-now)
Post #619574 26th Apr 2017 6:38am
A fairly common problem on the TD5 is for the vacuum pump mounted at the front of the alternator to leak oil into the alternator itself, causing it to fail.
Since the alternator/vac pump is only available as a single assembly, there isn't a great deal you can do about this except replace the entire unit.
It is also common on high mileage engines for the the slip rings and brishes to wear excessively. Again, it doesn't seem possible to buy replacement slip rings for these alternators (at least, I can't find any) so replacement is really the only option.
Post #619586 26th Apr 2017 7:47am
jst
it could be a snapped ancil belt, which means coolant not been circulated. check under bonnet first, assuming you have not seen vehicle?
if belt is good then as above. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #619617 26th Apr 2017 10:15am
Nutter
Make sure your brake lights work as battery light on same fuse i believe.
James
Post #619633 26th Apr 2017 12:12pm
