Home > In Car Electronics > Wiring Electrically Heated Seats.
Woodruffsdad
United Kingdom 2005 Defender 110 2.5 TD SW Zambezi Silver
I've had an auto electrician look at the seat wiring on my 2005 Defender 110 Td5 Station Wagon. There are heating pads in the seats. The wiring is all present under the seats to connect the seat pads. What is missing is the wiring from the seats themselves to the switches on the dash plus the switches themselves (blanked off at present). The electrician has confirmed that there is no seat wiring behind the blanks. I have done a little research and have found that the wiring from seats to switches costs around £200. Is there a cheaper alternative? I don't want to spend so much money on something I'll only use a few times a year!
 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows.
Post #614646 5th Apr 2017 10:24am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Post #614688 5th Apr 2017 3:32pm
Woodruffsdad
Thank you very much. Looks good! 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows.
Post #614691 5th Apr 2017 3:48pm
It is the FCX kit that I have. Thumbs Up KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #614710 5th Apr 2017 5:57pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
You only need the switches two fuses and some 2mm thin walled cable, fused live to switch then from switch to seat, earth from seat to body.
No relay needed, not timer if Genuine seats as they have a heat cut off
Post #614772 5th Apr 2017 8:44pm
Woodruffsdad
Thumbs Up 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows.
Post #614800 5th Apr 2017 10:51pm
Woodruffsdad
Post #614801 5th Apr 2017 10:52pm
HeX
Hi,
I just bought some used original heated seats from a Defender which I wanted to wire up. It's going into a Ninety so I wanted to go for the universal type of switches of this type:
Now this offers the possibility of having 2 levels. The original wiring has the seat and the back connected in series. So I thought of making level 2 in parallel and level one in series.
Question is, will the heat elements manage the parallel connection and not overheat? Any experience?
Post #617700 18th Apr 2017 2:51pm
meeerrrk
HeX
might be worth looking at the kit Exmoor Trim sell, that should allow you to connect it all up and use those switches, which is what I have fitted. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #617715 18th Apr 2017 3:40pm
HeX
Thanks but the seats I've bough already have the heating installed. So I just wonder if I can use them they way I intended without damaging them.
Post #617716 18th Apr 2017 3:42pm
jst
consider options on ebay from Weaco, they sell sets for around £20 for one seat with all the wiring, scrap their pads and use their wiring kit. in fact their pads are good to. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #617744 18th Apr 2017 5:40pm
I use the Genuine switches the FCX kit with Waeco pads.
Never seen the need to use the warm up, I've used it before and it heats fast and then you have to change over.
The constant setting is more than adequate and heats up just as quick.
So I just use single pole switchng fir constant heat using Genuine switches. KEEP CALM AND Drill ON
Post #617773 18th Apr 2017 7:25pm
HeX
@ custom90steve Yes that is probably what I'm gonna end up doing. Genuine switches won't fit the style though. They would look strange in a 1989 Ninety with no other switch looking like that Smile
@jst I know there are all kinds of sets i can buy but I was trying to find out if somebody had tried connecting them in parallel and if they would manage with direct 12V supply to each element. I'm not interested tearing my perfect seats apart yet Wink
Post #617847 19th Apr 2017 6:36am
Lancerdoc999
mobilecentre also make a couple of wiring sets with different switches
Post #618001 19th Apr 2017 8:12pm
V8Smith
Ive seen the wires and switches from Mobilecentre, anyone know if they are any good?
Post #623642 12th May 2017 1:53pm
