Home > Puma (Tdci) > Lower swivel pin leaking from gasket. |
Have a spare one shot and some time on hand then try?
I would have thought the escaping oil would make the sealant applicaton a bit troublesome, all the while it's leaking and leaking.. Then is it going to cure properly etc. Solved the bowel problem, working on the consonants... |
16th Apr 2017 6:42pm |
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 |
Mmmm, yes the leaking grease was one of my issues, especially getting the sealant to cure properly. I have plenty of spare one shot, so thats not an issue.
Here in Victoria at the moment the weather is cold, and the one shot in the tubes is pretty thick. Usually when using it before, I've heated it up in a container of hot water, just to get it to flow better out of the tube. So it would be interesting to see how much tried to escape when I lower the pin. I'll have a go this weekend, nothing ventured nothing gained. |
16th Apr 2017 9:22pm |
