Home > Maintenance & Modifications > MOT (A boring question!) |
Matt90 Member Since: 12 Jun 2016 Location: Leicester Posts: 142 |
My 90 sailed thought its last mot with no advisories 😗🎶
15th Apr 2017 9:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20540 |
No Guts, No Glory.
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
15th Apr 2017 11:05pm |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 |
Not sure about lights but spare wheels are definitely tested if present. They're one of those weird ones; you don't have to have one but if you have it has to work.
I guess the same could be true of extra lights etc. The definition of insanity is doing the same thing over and over again but expecting different results. Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
15th Apr 2017 11:18pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Mine had its mot last week and if the tester didn't know me it would have failed..... The reason being, I had given him the spare set of keys with no fuel cap key and apparently they have to check the fuel cap seal integrity Ray
15th Apr 2017 11:42pm |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
I have the standard lockable fuel cap and every MOT has an advisory that the temporary cap has to be replaced!
16th Apr 2017 6:42am |
Not true, it's not a testable item. If a tester happens to notice that it's cracked and falling to bits they can give you an advisory for it, but it has never been a reason for failure. Point 4.1 of the MOT inspection manual;
Given that Defender wheels are usually hung on the back door and very visible they're easily noticed.
That's not true either. Section 1.9 MOT Manual
So a push on rubber cover isn't going to stop them looking.
Spotlights don't have to work in the MOT. However they are supposed to go out when the headlamps are dipped or have covers fitted to them if they don't(which effectively means they're no longer lamps). Other than that unless they have dangerously exposed edges or perhaps liable to fall off the vehicle they're not a fail.
Almost. Clear plastic covers are ok, like the clear headlamp protectors Land Rover sell. Usually in the manual it specifically says if a tester should remove a cover from an item to test it. Basically it's common sense. If it's just a push on cover like a trailer socket cover it'll say remove it if present. But they're not allowed to go dismantling half the car. It's all here; https://www.mot-testing.service.gov.uk/doc...000101.htm |
16th Apr 2017 7:20am |
Because the tester is an idiot.
Not quite. It wouldn't have "failed" per se, but he could have refused to test it. The difference being if it failed they'd have charged you and issued you with a failure. However a refusal to test isn't chargable and they have to refund you if you've paid.
16th Apr 2017 7:28am |
Some of it really does go beyond sensible conclusion lately I do admit. No Guts, No Glory.
16th Apr 2017 9:53am |
My favourite is the "arse covering" advisories you get. like "covers fitted to engine bay, preventing inspection", which pretty much all modern cars have fitted from the factory these days.
So if the battery turns out to be insecure, the tester can't be blamed for passing it because it had two screws holding a cover on. |
16th Apr 2017 12:11pm |
