Home > Puma (Tdci) > Power Steering has gone missing? |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Can you disconnect the power steering? How heavy is the steering if you do that?
14th Apr 2017 8:41am |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
With 285 width tyres it's VERY heavy
15th Apr 2017 11:51am |
I meant if you have a power steering failure a long way from home, could you get under the car and do some spannering to get yourself home. I figures you'd be steering against the (failed) pump so disconnect the pump and get some steering back. It's what I like about the Defender, in the event of a failure of something, pull some fuses for whatever has failed and you can still drive (such as the anti-locking brakes, for example (I assume as everything seems to be an add on rather than being integral to the workings of the car in modern wiring looms).
15th Apr 2017 2:10pm |
There is no problem to drive when it's failed as there is still a mechanical link. But a system that's designed to be power assisted is very heavy when there is no assistance. As soon as your moving its fine, it's just going slowly that's a problem.
My vehicle is going in at the beginning of May for a few warranty bits so I will get them to pressure test the power steering system. But after the initial failure and miraculous fix, I'm thinking it was just air in the system or the pressure regulator stuck open. |
15th Apr 2017 3:58pm |
Yeah you can still drive it, you wouldn't need to disconnect anything, it's just a bitch to park. Power steering doesnt really do much at speed, in fact on most modern cars it's speed sensitive and basically switches off on the motorway. It's not exclusive to Defenders though it's the same on any car, with a power steering failure (or ABS failure), you don't need to do anything. The steering will still work and the brakes will still work, you just wont have the benefit PAS or ABS. They're all designed that you can still drive them when a system fails. The only exception i can think of is the fully hydraulic steering on some tractors and plant machinery, if that fails then you have no steering. |
15th Apr 2017 7:02pm |
